Re: good price for frame? [Re: Digital_Aardvark] #684564 01/10/06 02:11 PM
Elbow_Greese Offline
Just FYI, the steering box for the 2wd is different than the 4wd. I'm having to change mine over for my SAS.
So you know, the ride height of mine will only be a few inches taller than a stock 4wd. Using 33's will be fine (not look goofy small).
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: good price for frame? [Re: Elbow_Greese] #684565 01/10/06 07:49 PM
kyle-22r Offline
you could use a 2wd box for an SAS. however it's slightly smaller and mounts with 2 bolts rather than 3. on the upside, the pitman arm on a 2wd has less drop and allows for more leaf spring clearance.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: good price for frame? [Re: Elbow_Greese] #684566 01/10/06 10:42 PM
Digital_Aardvark Offline OP
thats good to know <img src="/forums/images/graemlins/cheers.gif" alt="" />
i wonder if the pitman arms would swap over from the 2wd to the 4wd box? The arms are probably frozen on the shafts anyways, but it would be interesting to know.
1989 3.0 5 spd extended cab with more rust than should be legally aloud, soon to have a D44 front and D60 rear
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6017 MB (Peak: 0.6712 MB) Data Comp: Off Server Time: 2026-06-10 06:35:01 UTC
