How much would it cost to put dual cases in my truck?
#684815
01/11/06 02:05 AM
after i buy the $350 adapter kit from marlin, can i just get another stock tcase and bolt them up. i know id have to get a new driveshaft, but im not sure how much all of this will cost. i dont want to start spending money on something and then realize it is a lot more expensive than i thought.
Re: How much would it cost to put dual cases in my truck?
[Re: 87Toy4x4]
#684816
01/11/06 03:02 AM
It can add up to about $1000, but nowadays there are more products available and it can be done cheaper. The basics that you need:
the adapter shorten rear drive shaft $50-$75 lengthen front drive shaft $75-$100 buy the donor t-case and modify it (or buy a modified case from Marlin, Inchworm, etc.). get a new crossmember to protect the second case buy a second rubber t-case mount to bolt to the second case to the crossmember buy a cool third shifter knob, like a skull with light up eyes.
Jason '88 Toyota, flatbed junker, Inchworm dual cases, spooled rear.
[Re: 87Toy4x4]
#684817
01/11/06 01:50 PM
cost me around $600
mc08 adaptor ($475 got it from someone who was desperate for money, new still in box) L52 donor trans/transfer case $50 misc steel $50 oil , misc parts $25
did the work on d/s myself with friends help. front is square shaft rear is shortened
85 runner -dual cases, headlight harness, 34" TSL's 86 toy buggy getting sas'ed with a 14 bolt rear - 8.5" 10 bolt front (this will go away when i find a 60)
[Re: BeaterToyota]
#684818
01/11/06 02:55 PM
...buy a cool third shifter knob, like a skull with light up eyes. That's where the big $ goes. <img src="/forums/images/graemlins/notooth.gif" alt="" />
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 - '84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
[Re: fourwd1]
#684819
01/11/06 05:16 PM
Lessee...
The first time I did it cost over $3K. Marlin ultimate 23 spline w/ V6 adapter: $2400 Drive shafts: $750 Twin Stick: $200 crossmember: $50
<img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
Prices have dropped quite a bit since then, however.
Brian K. Gallus I have nothing important to say.
[Re: 87Toy4x4]
#684820
01/11/06 08:41 PM
Sorry to chime in, but what about Marlin Crawler's "Crawl Box?" I'm sort of oblivious as to all the transfer case stuff, but it should include a transfer case (or something with the same purpose and different name) AND the adapter AND shifter knob (sorry, no skulls though). I'd figure it would be everything needed except mod's to the floor board, drive lines, and cross member. Am I reading this right or am I confused? http://www.marlincrawler.com/htm/transfercase/pickup_dual.htmCalled "Crawl Box Dual Crawler Kit"
[Re: labomba89]
#684821
01/11/06 11:18 PM
Sorry to chime in, but what about Marlin Crawler's "Crawl Box?" I'm sort of oblivious as to all the transfer case stuff, but it should include a transfer case (or something with the same purpose and different name) AND the adapter AND shifter knob (sorry, no skulls though). I'd figure it would be everything needed except mod's to the floor board, drive lines, and cross member. Am I reading this right or am I confused? http://www.marlincrawler.com/htm/transfercase/pickup_dual.htmCalled "Crawl Box Dual Crawler Kit" Dual cases are really 1 1/2 cases, that is the 1/2 part. You also need another gear driven case behind that, preferably 23 spline.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
[Re: mt_goat]
#684822
01/11/06 11:49 PM
so i can just get the dual case kit for $659 and only worry about the driveshaft?
[Re: 87Toy4x4]
#684823
01/11/06 11:54 PM
Toyota Moderator
so i can just get the dual case kit for $659 and only worry about the driveshaft? Not exactly. In addition to the driveshaftS (and driveline angles) you would need a new crossmember. Plus, your truck likely has a G series transmission and forward shift transfer case that will need to be converted to a top shift case in order to work with the dual transfer cases. You can likely swap your forward shifting case for a complete top shifter from Inchworm or Marlin for an additional price.
[Re: DirtyHarry]
#684824
01/12/06 12:13 AM
yeah i know i have to replace the crossmember. i was planning on doing that first w/ one from budbuilt. i do have a g52 transmission though so i guess i would have to convert it. if i had a r151 would i have to convert it to top shift?
