low oil pressure #685003 01/11/06 03:41 PM
V
Viking_t Offline OP
Hi all
I have C223T engine with oil pressure problem.
1: When the engine starts it takes about 7-8 seconds for the mechanical oil gauge to register however the warning light goes off straight away.
2: The mechanical oil gauge starts to show at 4kg/cm3 then drop to about 2kg/cm3 when engine warm up and read around 1kg/cm3 at idling and goes back up to 2kg/cm3 at around 2000rpm. I am using 20w-50 oil. Is this presure normal? is the delay in oil pressure gauge normal?
Thanks Heaps
Trong
Re: low oil pressure [Re: Viking_t] #685004 01/13/06 07:55 AM
If you're talking about the 2.8DT engines, in our case the '92 - 2001 models, the pressure readings looks(sounds) normal.
When the oil is still cold @revs above 2000 the reading will be around 4bar, as it heats up, at idle it will be 1bar and at normal working revelutions (2500 - 3250) it can be between 2-3bar
Use a good quality multi grade oil, shell super rumela X for example, and change it on regular intervals, and you should not have any problems.
Re: low oil pressure #685005 01/13/06 02:02 PM
kravdraa Offline
I noticed that in the first post the author mentioned kg's of pressure. The second post mentioned "bars" (Atmospheres?) of pressure.
If I am not mistaken 1 kg is 2.2 pounds. I bar is 14.7 pounds.
Am I missing something.
Respectfully,
Eric
Re: low oil pressure #685006 01/13/06 02:11 PM
V
Viking_t Offline OP
Hi Thank you for your reply.
My is 2.2 TD, its on 1985 Holden Jackaroo (same as Tropper in US I think)
1KG/cm2~1 bar~14psi
So my is running at 14psi with Idle speed and 30psi at 2000rpm
Re: low oil pressure [Re: Viking_t] #685007 01/13/06 07:56 PM
kravdraa Offline
Oh, OK. I didn't realize it was the same thing.
Thank you clearing that up.
Eric
Re: low oil pressure [Re: Viking_t] #685008 01/13/06 10:22 PM
This behavior appears to be normal. My '86 did this with a C223-T. I was running Amsoil Marine Diesel 15x40 in it.
I had the stock electric oil pressure guage in it, and replaced the sender. The guage read a little higher, but the behavior was about the same. According to Jerry Lemond, who has forgotten more about Troopers than I will ever know, this kind of behavior says it is normal behavior.
I don't like it either, but since these engines are known for being very long lived it must not be too much of a problem.
AP
Re: low oil pressure #685009 01/14/06 02:18 AM
V
Viking_t Offline OP
Thank you all for your replies
FYI
kg/cm2 x 0.9804 = bar
kg/cm2 x 14.223 = psi or lb/in2
I found this in someother forum and I think it makes sense in someway
Trong
(Msg. 1) Posted: Sat Jan 22, 2005 6:40 pm
Post subject: Low oil pressure at idle 93 Trooper
Archived from groups: alt>autos>isuzu (more info?)
A few days ago I noticed that when at idle my oil pressure needle flutters
just above 0 and the oil light flickers on and off. Once I'm on the gas the
pressure seems fine. This happens more often then not but it is a random
thing. Oil levels are fine. As a mater of fact, I just added oil prior to
noticing this problem.
What should I be looking at. Pressure sensor? Oil pump? Any other ideas?
(Msg. 3) Posted: Mon Jan 24, 2005 2:35 am
Post subject: Re: Low oil pressure at idle 93 Trooper [in reply to: Login to View]
I used to own an 85 Isuzu 2.2 turbo diesel C223 engine in a Jackeroo. The engine being an old diesel it suffered from exactly the same problem and after checking with a capillary type gauge I noticed that the oil pressure at idle when cold used to be at 85 P.S.I. (which is a lot higher than any petrol engine that I have owned)and when hot at idle used to drop to as low as 10 P.S.I. sometimes even 5 P.S.I.
Once the engine revs were raised up the oil presssure then went up to about 45-60 when hot. So it was only ever a problem at idle. I have been told that this is a common thing that happens to old diesels and not to worry to much about it.
It is caused by wear in the big end bearings thus increasing the clearances between the con-rod and bearing. Due to the extra clearance the pump has trouble keeping up pressure and the fact that the turbo heats the oil more than normal wouldn't help either. But this only a problem at idle when the engine is under no load anyway.
I used to run a 15W/40 weight oil, but because of my problem tried using a straight 30 weight oil, but this actually made it a bit worse. My next step was going to be, trying a penrite oil 20W/60 which I have no dought would of fixed the problem. But I got rid of the car before I had a chance to find out.
However mine was never that bad that the temp light came on. They are normally set at around 3-5 P.S.I.
If I were you I would check the oil pressure with a capillary type gauge just to rule out a possible elctrical type fault. If your pressure comes reasonably high with this gauge when cold then you can probably rule out a problem with your oil pump and put down the pressure drop to increased clearances inside your engine.
I would also check if the idle speed is set high enough. If it is, it probably wouldn't hurt to bring it up about 150-200 R.P.M. anyway, which should raise your pressure by a bit at idle.
Just as an exercise - When turning off your engine switch it straight back to the ign positon and see how long it takes for you oil light to come back on. When cold it may take as long as 5-10 seconds. When hot it will come back on nearly straight away. On a newer engine even when hot it will still hold its pressure for about 3-5 seconds.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6142 MB (Peak: 0.7075 MB) Data Comp: Off Server Time: 2026-06-22 06:04:30 UTC
