How do you change an R4 A/C compressor CLUTCH (2.8 V6 Trooper) #685010 01/11/06 05:36 PM
greauxpete Offline OP
Hello,
Has anyone ever changed an R4 A/C compressor clutch
(Trooper 2.8L V6). I bought a reman'd R4 compressor and clutch last year and the compressor is fine but the clutch will not engage sometimes.. I have checked my battery and alternator and both are putting out properly. I find that if i tap the front of the clutch when the A/C is on it will engage. Has anyone ever changed this A/C clutch without evacuating the system? I know there is a tool used to get the clutch off but i am not sure which one, as there are many out there.. i have read that the clutch is a press fit with a bolt on the end. any help is appreciated...
1990 Isuzu Trooper 2.8L V6
Re: How do you change an R4 A/C compressor CLUTCH (2.8 V6 Trooper) [Re: greauxpete] #685011 01/12/06 10:50 PM
1
1sttrooperII Offline
you might check the airgap first, as too much gap will cause your problem. the air gap can be adjusted easily
by tapping the hub back using some type of "socket" that protects the compressor shaft. gap should be .036-.042
Re: How do you change an R4 A/C compressor CLUTCH (2.8 V6 Trooper) [Re: greauxpete] #685012 01/13/06 04:19 PM
F
Fujisawa_Rob Offline
AFAIK you'll need snap ring pliers (I bought a cheap Harbor Freight set for $10) and a GM R4 clutch puller/installer like RobinAir #10861 (under $20).
I need to adjust my gap too (pull shim(s)) since the clutch won't engage unless I whack it with a rubber mallet...haven't done it yet.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: How do you change an R4 A/C compressor CLUTCH (2.8 V6 Trooper) [Re: Fujisawa_Rob] #685013 01/13/06 08:00 PM
1
R-4 compressors do not use shims. They are a
"press-fit", therefore you press the hub off or on.
the gap can be closed simply by tapping the hub back in the center. DO NOT TAP ON THE VERY CENTER, IT IS THE CRANKSHAFT OF THE COMP. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: How do you change an R4 A/C compressor CLUTCH (2.8 V6 Trooper) [Re: 1sttrooperII] #685014 01/17/06 03:30 PM
Guys,
thanks a lot for the replys....
after reading the post i went outside and tapped the front fo the compressor with a hammer (firmly) to reduce the air gap and the now the compressor cycles perfectly without needing a tap on the front of the compressor occasionally...
Question: The compressor has worked fine for the past 2 days
(believe it or not 80 degree daytime heat in louisiana). Is there anything i need to do to make sure that the air gap does not go back to where it was? do i need to tighten anything or is it kept in place with with the press fit as mentioned earlier?
Thanks Again for the advice...
Re: How do you change an R4 A/C compressor CLUTCH (2.8 V6 Trooper) [Re: greauxpete] #685015 01/19/06 11:16 PM
1
It won't move if nothing is worn out.
Glad it worked out for you.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6128 MB (Peak: 0.6834 MB) Data Comp: Off Server Time: 2026-06-21 00:16:15 UTC
