Double chain on a 22RE? #685100 01/11/06 09:47 PM
Squishy Offline OP
My buddy wants to know if you can put a double chain on a fuel injected 22R. Spacing issues? Reliablity? Cost efficient? He also thinks it will last the lifetime of the engine. Is this true?
Justin Morgan-Speed never killed anyone, it's the sudden stop at the end that'll get ya
1988 Toyota 1/2 ton
Solid front axle, locked fore and aft, 35's and 5.29s.
Re: Double chain on a 22RE? [Re: Squishy] #685101 01/11/06 09:55 PM
willzrunna96 Offline
my pretty sure LC engineering makes a kit not to cheap though
Re: Double chain on a 22RE? [Re: willzrunna96] #685102 01/11/06 10:27 PM
kyle-22r Offline
cost definitely outweighs the benefits, unless it's an '83-84 22RE where you can swap the oil pump drive spline, and order a timing set for an '81-82 22R.
on a later engine, just get a steel rail kit and forget about it.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Double chain on a 22RE? [Re: Squishy] #685103 01/12/06 12:15 AM
Esquire812 Offline
You'll kinda run into a few issues if just installing a dual chain setup meant for the 81'-82' engines.
And if you go the LCEngineering route, its just putting out alot of money for no real benefit (other than stoutness). You will give up some crankshaft torque (really low amount) due to increasing the weight of your rotating assembly...yeah it takes power to make things turn.
Read HERE to learn what you can and cant do based on small design changes over the years the engine was produced. Good stuff for keeping in the bathroom for when you are "thinking"....
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Double chain on a 22RE? [Re: Squishy] #685104 01/12/06 07:46 AM
I looked into the double row chain kit from LC when I purchased my adjustable cam gear, I think it's really intended for real high lift cams that run dual or triple valve springs.
But I do recall reading that their kit includes a new modified early timing cover which has been shortened to fit the later blocks (shorter deck height than the early blocks)
I think the only advantage would be less overall chain stretch and just extends the chain replacement intervals.
If you get hold of a adjustable timing gear for the single row like I did, you can compensate for the chain stretching which makes the valve timing run late. As long as the chain is kept snug it won't break, but if the chain stretches beyond the tensioner travel, then the chain will run sloppy and eventually break.
But you could spend the money elsewhere, like gas for a month.
Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Double chain on a 22RE? #685105 01/13/06 02:59 AM
kyle-22r Offline
if you adjust the chain to run tighter on the driver's side, the tensioner might not be able to take up the slack and you'll waste the timing set anyway!
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6108 MB (Peak: 0.6971 MB) Data Comp: Off Server Time: 2026-05-29 21:07:11 UTC
