Re: 3.2 DOHC Idle surge on startup [Re: m_a_b] #685232 01/20/06 07:32 AM
Michelle Offline
I had the O2 sensors replaced after the IMG as it was still setting off codes. No more codes but still have the surging.
Re: 3.2 DOHC Idle surge on startup [Re: ProBMXer1313] #685233 01/22/06 05:05 AM
I had that problem (well still have but much more tamed now) and result to be the vacuum hose to the fuel regulator cut halfway, will give you full fuel pressure all the time, more fuel compsumption and the vacum leak mess up the tranny shift ritm, does it sounds familiar?
Re: 3.2 DOHC Idle surge on startup #685234 01/22/06 05:08 AM
ProBMXer1313 Offline OP
Ya fixed that one too when I did all the other above mentioned stuff, broken line caused me to burn up 3 catalytic converters.
1998 Honda Passport EXL V6 3.2L Auto SOTF 4WD
3" Calmini Lift w/ HD Track Bar, 32x11.5-16 Super Swamper SX, Aisins
[color:"blue"]http://www.CarDomain.com/ID/ProBMXer1313[/color]
Re: 3.2 DOHC Idle surge on startup [Re: ProBMXer1313] #685235 01/26/06 05:19 AM
JohnW Offline
Check IAC for proper function.
2002 Trooper S 5spd, cone filter, Ranchos, Modified for 2WL
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6018 MB (Peak: 0.6757 MB) Data Comp: Off Server Time: 2026-06-09 10:04:06 UTC
