Page 1 of 3 1 2 3
Home mechanic alignment? #686039 01/14/06 04:10 PM
V
Voyager Offline OP
So, I got my truck back from the local dealer today after taking it in for the steering rod recall in the vein hope that they would align it afterward. Nope. <img src="/forums/images/graemlins/confused.gif" alt="" />
Since I have 33" tires and ball joint spacers(IFS), my truck provides shops without the will, knowledge, or time a handy excuse to avoid trying to align it. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Since I also move about once a year, and change suspension settings about as frequently, the process of exhausting the yellow pages of these characters has grown tiresome.
So...all that to say. I know alignment is a very exacting and complicated problem with many variables. Has anyone undertaken this problem themselves that yeilds an 80% solution and can be done in the garage with home tools?
Sid
89 extra cab 4x4 3.0 5 spd, 216K
4.56, Supra LSD, Lock Rite
Re: Home mechanic alignment? [Re: Voyager] #686040 01/14/06 06:35 PM
4Crawler Offline
Re: Home mechanic alignment? [Re: Voyager] #686041 01/14/06 06:59 PM
elripster Offline
Voyager, if you have any questions about that link post up and I'll do my best to answer. I had very good luck using the method I described on my truck and would recommend it. It saves a lot of money!
Frank
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
Re: Home mechanic alignment? [Re: elripster] #686042 01/14/06 08:40 PM
V
Voyager Offline OP
This is exactly what I wanted & exactly why I love this forum. Thanks Frank & Roger. I'm so motivated to do this that I am going to STOP working on my research paper and go try it RIGHT NOW!(like I needed an excuse to do that <img src="/forums/images/graemlins/lol.gif" alt="" /> )
Sid
Re: Home mechanic alignment? [Re: elripster] #686043 01/14/06 11:54 PM
V
Voyager Offline OP
OK, I got pretty close on the camber which was the most visually obvious problem & also corrected most of my pull to the left. Though I can't see anything obviously bent, the bolts point in pretty different directions now but they are square to the floor.
Now, the whole string measurement thing has got me puzzled.
Tape the string to the front tire & walk rearward. Got it. Now Measure what? Is a string just a straight edge for the outer surfaces of the front & rear wheels? So, if the outer surfaces of the rear wheel are lined up (both touching the string) and the back part of the front wheel is not touching the string I have toe out and need to adjust until both surfaces of the front touch the string. Is that it?
Without pictures I would have thought you were measuring string distance from front left to front right at the front and rear of the wheels & adjusting until the measurement was the same, or slightly less in the front. Is that where the 1/8" greater measurement comes in? <img src="/forums/images/graemlins/confused.gif" alt="" />
Sid
Re: Home mechanic alignment? [Re: Voyager] #686044 01/15/06 12:58 AM
4Crawler Offline
Here is how I align my front end (solid axle but the toe in part is the same):
http://www.4crawler.com/4x4/CheapTricks/AxleTech/index.shtml#Alignment
Re: Home mechanic alignment? [Re: 4Crawler] #686045 01/15/06 01:14 AM
V
Voyager Offline OP
Now that I can do! <img src="/forums/images/graemlins/cheers.gif" alt="" /> Thanks much. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sid
Re: Home mechanic alignment? [Re: Voyager] #686046 01/16/06 02:04 AM
elripster Offline
To clarify the 1/8" measurement. You are basically using the string to get the front tires pointing in the same direction as the rear tires. So, let's say your front tires stick out farther than the rear as was the case on my truck. You would tape the string to the front of the front tire and walk with it to the rear tire. Angle the string inwards until is just touches the rear (side) of the front tire. This is the direction that front tire is pointing. You can now measure the distance from the string to the front and rear side of the rear tire. If it measures the same, the front tire is pointing in the same direction as the rear tire. This is good. If the front tire is pointing in a bit, the string will be farther away from the rear side of the rear tire. That's where the 1/8" difference comes in. A slight bit of toe in means that string is a little farther from the rear side of the rear tire compared to the front. It's a 1/8" difference so if you are 1" away from the front side of the rear tire, you are 1 1/8" away from the rear side of that tire.
Hope that helps.
Frank
www.sdori.com
Re: Home mechanic alignment? [Re: elripster] #686047 01/16/06 02:50 PM
V
Voyager Offline OP
Thanks Frank! Yea that does help. I was amazed how far off my tow was (2 inches). I need to go back and adjust my camber again too.
Is there way for ME to measure my caster angle and adjust it on the IFS? Most of the links talked about alignment shops getting that measurement. I think I recall it was 6 degrees?
Sid
Re: Home mechanic alignment? [Re: Voyager] #686048 01/16/06 05:37 PM
4Crawler Offline
On IFS, I think only a litle caster adjustment is possible, that I am aware of. If it is off a great deal, something is bent.
On solid axle, no camber adjustment (outside of some expensive camber shims behind the spindle or offset knuckle bearings) so if camber is off, something is bent.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.017s Queries: 16 (0.013s) Memory: 0.6490 MB (Peak: 0.7713 MB) Data Comp: Off Server Time: 2026-11-18 03:20:13 UTC
