Engine loading up #686601 01/16/06 05:10 PM
salvo Offline OP
Got a strange problem that just started out of the blue... My truck feels like it is loading up with fuel if the rpm's are below 2500. If im sitting at a stop for to long it will slowely idle down untill it stalls. If im leaving from a stop i have to rev up over 2500 and work the clutch to get moving without if kicking and bucking... Its acting like it was the last time i got Distributor wet.. Checked dist and wires. and played around with the air mixture... If it would quit snowing i would pull the plugs and check them out.. not sure were else to look... Its good the first 5 min of driving then it starts acting up.. then after about 15 min it seems to get better but not perfect... This truck has always run good.
85 pickup EFI
Re: Engine loading up [Re: salvo] #686602 01/16/06 05:42 PM
4Crawler Offline
Check the vacuum line at the fuel pressure regulator. Is it hooked up? Does it go to a vacuum switching valve? Is the vacuum line from the VSV connected to the intake? Does the VSV actually swich on and off? For a quick test, bypass the VSV and connect the FPR directly to the intake.
Stock setup like this: http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/8.html
Modified like this: http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/10.html
Re: Engine loading up [Re: 4Crawler] #686603 01/19/06 12:29 AM
salvo Offline OP
that all looked good ... Checked all the plugs, wires, dist, timing, fuel filter today and all were good... pulled the code and got code 11 that pointed to TPS... Also would a bad O2 cause any of these symptoms? It feels like its starving for gas teh more i drive it and listen to it... If it was flooding up i should at least be able to smell it running rich?
Re: Engine loading up [Re: salvo] #686604 01/19/06 12:59 AM
4Crawler Offline
Test the TPS: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
And it is the O2 sensor that tells the ECU the amount of oxygen left in the exhaust and that is how it adjusts the air/fuel ratio. So if the O2 sensor is giving bad data back to the ECU. it could be getting the mixture wrong.
Re: Engine loading up [Re: 4Crawler] #686605 01/19/06 05:09 PM
salvo Offline OP
ya thats what im thinking.. I disconected the battery yesterday and gave the tps a few taps with the screwdriver... The problem has went away for now computer probably hasent set the code yet... But today its going into the shop to get looked at as i just dont have time right now to be screwing around all day trying to fix it...
Thanks for the help and info Roger
PHP: 7.4.33 Page Time: 0.119s Queries: 15 (0.005s) Memory: 0.6089 MB (Peak: 0.6744 MB) Data Comp: Off Server Time: 2026-10-24 13:07:53 UTC
