Clutch question??? #686741 01/17/06 02:32 AM
O
OneStar Offline OP
First off let me say I know next to nothing about clutches, but I am a mechannical designer so I know I wont get lost in your translation. I've always been an automatic guy. But I must say the stick is growing on me.
O.K. Just bought my 89 pickup deluxe (love this truck) with 125,000 miles in november of 05. Just recently (127,000 miles), it seems that the clutch doesn't engage as well as it used too. It seems to catch 1/2 way to 3/4 of the way up on the clutch pedal. The T.O. bearing was replaced last summer (so I'm told by the last owner). Also, around the same time, the clutch pedal sqweaks alittle when fully pressed, but not all the time. There is no actually noise other than the sqweak or vibration that I can hear or feel.
Do I need a new clutch soon? Maybe some kind of an adjustment needs to be made? Or could the extremely cold weather here in the north east cause this?
Thanks in advance.
Re: Clutch question??? [Re: OneStar] #686742 01/17/06 02:41 AM
Talon84X4 Offline
I don't have an answer to your question, but can relate on one point, the squeek <img src="/forums/images/graemlins/lol.gif" alt="" />. It only does it when i push all the way down, and my clutch is fairly new, so i don't think that has affect on it's performance.....could be wrong though. As for the the catch on the level of clutch pedal, stupid question but have you checked the fluid? that or the line might need to be bled. Every once in a while i'll have an intermitten issue where the pedal has to be pushed as far as i can possible get it to get the truck to shift....don't know what the cause is as well...but doesn't happen very often at all.
'84 PU low & slow
Central Valley Crawlers
Re: Clutch question??? [Re: OneStar] #686743 01/17/06 03:18 AM
Generally a worn out clutch will start slipping when in higher gears under a load. You do not need a new clutch....maybe a little tweak and some lube on the pedal but your clutch is fine.
If the TO bearing was just replaced...my guess was they either put a new clutch in it or it was in very good shape and didn't need it. Anyone who goes thru the work to put a TO bearing in and ignores a bum clutch should be shot....twice.
Re: Clutch question??? #686744 01/17/06 07:26 AM
4WD22R Offline
and then be hung from a tree to be a warning to all. <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Clutch question??? #686745 01/18/06 02:36 AM
O
OneStar Offline OP
what would "tweaking" imply??
Thanks....
Re: Clutch question??? [Re: OneStar] #686746 01/18/06 02:49 AM
Adjust freeplay on pedal....bout all you can do really.
Re: Clutch question??? #686747 01/18/06 03:00 AM
Scerb Offline
Definently bleed the line. Same procedure as bleeding brakes.. clutch bleeder valve is on the clutch slave cylinder (below the starter). That should make it engage quicker. If this is your first manual, it may be learning how to drive it has worn the clutch a bit. Yota clutches are very durable, and you don't have anyhting to worry about until it starts slipping. As long as it doesn't slip.. you should be all set for now.
Hope taht helps,
Scerb
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.015s) Memory: 0.6111 MB (Peak: 0.6892 MB) Data Comp: Off Server Time: 2026-11-18 22:34:02 UTC
