electric fan question
#686842
01/17/06 06:14 AM
im about to order a rad fan to replace that damn clutched p.o.s. on my 22r. how many cfm is needed to cool sufficiently? jegs has all kinds.
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: electric fan question
[Re: lookmomnobrains]
#686843
01/17/06 06:23 AM
Why electric? I have a 14 inch electric but only so I can turn it off when mudding. It wont cool any better, and probably worse since you wont have a shroud. Also, my fan blade and shroud was broke and it would have cost just as much to replace them through Toyota as it was for the electric fan conversion. over heating problems are most probably caused by a bad head gasket, clogged radiator, or a bad water pump.
Michael J. Carsner proud driver of "Aint Pretty"  37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor. MUD!!! Its whats for dinner!!
[Re: half_fast]
#686844
01/17/06 06:36 AM
im just sick of replacing clutches. im not overheating. they dont like it when you rev your motor to hell. they end up dead or stuck on. ive been through 2 in the last year. and i like the ability to choose when the fan kicks on.
#686845
01/17/06 06:50 AM
I used to run the Flex-a-lite, I think it was rated 2800 CFM. Did not cool quite as well as the stock fan clutch, but was sufficient. Here are the FAL fan specs: http://www.flex-a-lite.com/auto/html/toyota-4x4.htmlOn the fan clutches, I have found the Aisin part from the dealer are 10X better than the no-name parts you get elsewhere. I had one from NAPA puke all the silicone oil out all over the engine after less than 1 year's use. Still trying to clean that oil off the underside of the hood. Even after 7 years, dust will stick to the places that silicone oil splattered.
[Re: 4Crawler]
#686846
01/17/06 06:54 AM
wow 2800? i was looking at this: http://www.jegs.com/webapp/wcs/stor...egoryId=24285&searchItemId=96715if 2800 didnt work this wont have a hope in hell. <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: 4Crawler]
#686847
01/17/06 06:56 AM
just curious how do you know your clutch is bad. i can hear my fan and then sometimes i cant, its kinda driving me nuts. i priced one at the zone today and its 40 bucks lifetime warranty
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
#686849
01/17/06 07:03 AM
If you've got a three row? than a lower power fan will work. A german fan from the junkyard will work.
I have a BlackMagic but its overkill and cost close to $200. It only comes on in heavy traffic and almost never in the winter times.
[Re: willzrunna96]
#686850
01/17/06 07:04 AM
in my case i will stop at a light and sit for 30 seconds. at takeoff it will spin up then fade out. now progressively it is staying on more and more. its on all the time now. i know im not overheating. it has happened to me where the fan never kicks on which can be much worse.
#686851
01/19/06 09:22 PM
I run a 3 core radiator and a 16" fan. If you get wet or mud, make sure it's switched. Has to be a fairly thin fan, however..
I've seen the temperature controlled mechanisms fail time and again, I will no longer run one. Just run a good sized 30A relay.
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
