Pre-runner fenders! Do they exist? #686987 01/17/06 04:37 PM
I
islandracer Offline OP
I Wanna build up a pre-runner 2WD truck. Any body parts out there yet?
Appreciate any input with this build. I'll post pics after I pickup the donor truck.... <img src="/forums/images/graemlins/cheers.gif" alt="" />
B.Y.E. ~ Back Yard Engineering
Re: Pre-runner fenders! Do they exist? [Re: islandracer] #686988 01/17/06 05:07 PM
Bigpoppax2 Offline
I think Daniel was thinking about doing some fiberglass fenders at one point but I don't think they ever materialized.
I know he did make a set or two of flares for first gen Troopers.
I'm guessing you are on your own on this one.
Joe
Re: Pre-runner fenders! Do they exist? [Re: Bigpoppax2] #686989 01/17/06 05:18 PM
langforg Offline
I've seen some for an early model Ford Ranger that you might be able to make work.
Brad
95 Trooper,3in Lift,15x10 AR-23 Wheels, 33x12.50 BFG AT's, SuperWinch Hubs,Rock Sliders,Tie-Rod Shields,Cross-Drilled Brake Rotors,ARB Bull Bar...,looking for cheap winch.
Re: Pre-runner fenders! Do they exist? [Re: Bigpoppax2] #686990 01/17/06 06:21 PM
RobG Offline
Daniel did produce a set for his Trooper... and he's still got the molds. However, IIRC, it would require a pre-order of about 5 sets to make it worth his while to do another "production run".
-Rob
Re: Pre-runner fenders! Do they exist? [Re: islandracer] #686991 01/18/06 01:03 AM
troopin34 Offline
Awhile back I tried to make a crude mold using expanding foam and plaster of paris. The end result appeared as if I had done exactly what I did, simply put, it looked poopy. I have been barking up this tree for along time. Our only hope is if we get a small group order.
Here are some shops dedicated to making fenders
http://desert-industries.com
http://www.fiberwerx.com
http://www.flared-fenders.com
http://www.hannemannfiberglass.com
http://www.perrysfabnfiber.com/
Awhile back I talked to a fiberglass shop and they said they could make a mold if I sent in my fenders, and if I remember correctly the cost wasn't super high. The only problem is finding enough people with the same fenders to do it.
~Brady
Sunkist and Sudefed, Gyroscopes and Infrared
Re: Pre-runner fenders! Do they exist? [Re: troopin34] #686992 01/18/06 03:36 AM
I
Idaho_Trooper Offline
I would be interested in a set.... Would it be for the rear too?
James "MOZES" Tester
1988 Trooper SAS
Re: Pre-runner fenders! Do they exist? [Re: islandracer] #686993 01/18/06 08:13 AM
BroncosFan Offline
The fenders on the 1st generation Amigos have a more aggressive flare that look prerunner-ish. The front fenders are direct replacements for the fenders on the Rodeos and Pickups, just be sure to get both the inner and outer fenders.
I picked up a right-side Amigo fender for the swap on my Pickup and am currently looking for the left fender.
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
'92 Pickup - 2" BL, 1.5" SL, 4.3 TB swap, 2.25" exhaust, Amigo fenders
'93 Amigo - crawler in the works
Re: Pre-runner fenders! Do they exist? [Re: BroncosFan] #686994 01/18/06 03:32 PM
I
I'll settle for some Amigo fenders myself. Just thought someone had fabbed up something already.
Thanks for the input!
Re: Pre-runner fenders! Do they exist? [Re: troopin34] #686995 01/18/06 05:18 PM
Smiley Offline
I already had one of those websites bookmarked û hereÆs another one:
http://www.glassworksunlimited.com/
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Pre-runner fenders! Do they exist? [Re: islandracer] #686996 01/19/06 05:33 AM
9
94redrodeo Offline
Here is a couple pics of my rodeo with amigo fenders [Linked Image] [Linked Image]
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6313 MB (Peak: 0.7398 MB) Data Comp: Off Server Time: 2026-10-21 19:15:35 UTC
