Cool Molded Vinyl Flooring and Rubber Matting For Raider or Montero #687073 01/17/06 09:53 PM
photoduo Offline OP
I want to replace the soggy carpeting in my 1987 Dodge Raider with molded vinyl flooring....It rains a lot out here on the oregon coast and it would be easy to clean up after off-roading....I found a supplier but they only list it for 1983-1991 Mitsubishi Montero....Could someone please verify for me that the interior floor pan is the same for either 1987 Dodge or Mitsubishi....I hope so because it comes in cool colors (and camo too)!!!.... <img src="/forums/images/graemlins/smile.gif" alt="" />
ò Molded Vinyl Flooring Supplier ò
Here is another supplier for great trim to fit rubber mat selection for rear cargo area...Check out the "Shark Tooth" and "Elephant Bark" rubber products!!!
ò Rubber Mat Supplier ò
Astoria, Oregon Coast
1987 Dodge Raider
Re: Cool Molded Vinyl Flooring and Rubber Matting For Raider or Montero [Re: photoduo] #687074 01/18/06 12:58 AM
You should be good. What happens though when water gets under the covering? Why not get big, heavy duty, floor mats? Mine came from Wally-World for more like $40 for the front and rear (no cargo). They're big, durable, and pliable. Plus they come out easily when you need.
Re: Cool Molded Vinyl Flooring and Rubber Matting For Raider or Montero [Re: MontyMcV] #687075 01/18/06 02:24 AM
stony-man Offline
Daaang...$289 for mine, and only in black...but heck, black is what I'd get if I was gonna go that direction. I think I'd rather Herc it than put these matts down.
Re: Cool Molded Vinyl Flooring and Rubber Matting For Raider or Montero [Re: stony-man] #687076 01/18/06 03:33 AM
I've seen a few interiors done with Herculiner. They look so cool! The best job I've seen was sprayed on a Samurai interior. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Cool Molded Vinyl Flooring and Rubber Matting For Raider or Montero #687077 01/18/06 03:39 AM
juggernaut Offline
I did mine with the duplicolor brand bed coating from WallyWorld. I think a gallon was $40. I got 4 coats out of it. Holding up good so far. Local guys will Herc a Heep interior for $130ish I believe but I wheel on a budget and it is my DD.
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15
I caught this "JEEP thing" of your and now it hurts when I pee.
Re: Cool Molded Vinyl Flooring and Rubber Matting For Raider or Montero [Re: juggernaut] #687078 01/18/06 04:34 AM
photoduo Offline OP
I had been debating whether to do a bedliner coating on the floor or go with the vinyl flooring....The bedliner coating does make sense and can also deaden a lot of sound as well as protect all metal, and does not trap water....I was planning on buying some Durabak brush on coating to do inside the wheel wells....Durabak also comes in a lot of great colors...Check out the links below for their website....The photos of the Isuzu Trooper and Toyota Land Cruiser painted inside and outside are very convincing..... <img src="/forums/images/graemlins/smile.gif" alt="" />
Durabek Website
How to Apply Durabek
I purchased Durabak in the past from this online store to do the wheel wells on my Suburban....They are the only source that I could find that sells in quarts....And they take PayPal!....This is great so you can do a little area at a time, such as a wheel well each day....Remember...Once you open a can you have to use it all!!!!
Durabak Online Purchasing
1987 Dodge Raider
Re: Cool Molded Vinyl Flooring and Rubber Matting For Raider or Montero [Re: photoduo] #687079 01/18/06 05:12 AM
stony-man Offline
The guys on one of the Brit forums said they use that stuff multiple times. They make a whole in the can, so they can poor it into a containter, and then use a sheet metal screw or large bolt to screw back into the hole when done. Said it keeps it fresh, and they can use whenever...I think they make two wholes, one on top, one on bottom...top one is a "vent" hole...I figured I try that. I've also heard you can use 2 pieces of saran wrap one on lid, one on top of can, and that will enable it to be reopened...not sure if either method works. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Cool Molded Vinyl Flooring and Rubber Matting For Raider or Montero [Re: stony-man] #687080 01/18/06 06:26 PM
powerRam50 Offline
i have wanted to line X my floor for awhile.i might do it this year.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6252 MB (Peak: 0.7221 MB) Data Comp: Off Server Time: 2026-06-21 18:59:04 UTC
