new indy4x rock sliders (dial up beware) #687211 01/18/06 03:19 PM
A
anubis Offline OP
I figured that I would go ahead and plug these for matt before they hit his site. these are the sliders that Matt just made up for me. WOrk great so far with a jack. I next is to test them on a trail. woot woot
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: new indy4x rock sliders (dial up beware) [Re: anubis] #687212 01/18/06 05:22 PM
Bigpoppax2 Offline
I like that look, I made a set a few months ago that's the spitting image, short of one less cross piece.
If they were pretty afforable, I probably would have just bought them. But I did enjoy making mine.
Nice Sliders Matt.
Joe
Re: new indy4x rock sliders (dial up beware) [Re: anubis] #687213 01/18/06 08:50 PM
holger Offline
I do not get it: I see two different sorts of sliders, the ones on picture 3 are different from the sliders on pictures 1 & 2. This is puzzling.
Oleg
Deceased Rodeo'02 4WD.
Re: new indy4x rock sliders (dial up beware) [Re: holger] #687214 01/18/06 08:56 PM
Starchild Offline
I'm pretty sure it's just the angle of the last pic.
Looks good <img src="/forums/images/graemlins/kewl.gif" alt="" /> I'm assuming these are weld on, and that Matt installed them for you since you're so close.
They should serve you well.
What size and type of tube did he use?
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: new indy4x rock sliders (dial up beware) [Re: Starchild] #687215 01/18/06 10:01 PM
A
anubis Offline OP
all 3 are the same pics. just an angle difference. I belive it is all 2 inch tube. yea matt did install these for me.
Re: new indy4x rock sliders (dial up beware) [Re: Bigpoppax2] #687216 01/19/06 04:08 PM
TrailMystic Offline
Looks great, Bryan. Maybe I should remove my box-shaped rocker bars and put on tubular ones like your's. It would match my tubular winch bumper.
Pete
(P.S. Matt found a local guy here in Mechanicsville that sets up gears. My ARB locker is on the way)
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: new indy4x rock sliders (dial up beware) [Re: anubis] #687217 01/20/06 03:26 PM
matthew Offline
the tube on Brian's is all D.O.M..........the main rail is 2" and the rest is 1 3/4"
there are 3 supports welded to the frame.
here are a couple pics i took:
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: new indy4x rock sliders (dial up beware) [Re: matthew] #687218 01/20/06 05:13 PM
FEF Offline
Is the bottom tube unpluged? It looks open in one of the pics.
"Stubig" - '72 416.141 (U1100) Unimog
"Sassy" - '05 KLR650
"Brody" - '04 Rodeo (It's my wife's, really)
"Candy" - '02 TDI New Beetle (yes, a family of 4 fits inside)
"Twinkie" - '72 Revcon 250 (converting from Olds 455 to 6.5L Diesel)
Re: new indy4x rock sliders (dial up beware) [Re: FEF] #687219 01/20/06 06:41 PM
matthew Offline
nah.....it's capped.....just the pic.
i get pre-punched 3/16 tube caps and weld'em up <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: new indy4x rock sliders (dial up beware) [Re: FEF] #687220 01/25/06 09:21 PM
RodeoXS Offline
Glad I'm not the only one that thought that. They look nice. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
George <img src="/forums/images/graemlins/nana.gif" alt="" />
92 Rodeo XS 4x4
HomePage
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6373 MB (Peak: 0.7416 MB) Data Comp: Off Server Time: 2026-07-13 15:47:43 UTC
