Page 2 of 3 1 2 3
Re: Transfer Twin Sticks, What's the Best? [Re: bkg] #687439 01/20/06 05:57 AM
Plus it is another gadget to have. <img src="/forums/images/graemlins/smile.gif" alt="" />
Truth! <img src="/forums/images/graemlins/lol.gif" alt="" />
Looks cool
all your friends will have to get one too! <img src="/forums/images/graemlins/nana.gif" alt="" />[/quote]
Re: Transfer Twin Sticks, What's the Best? #687440 01/20/06 06:57 AM
4WD22R Offline
Looks cool
That combined with dual t-cases and a manual is sure to impress anyone who takes a ride with you....."You have 4 SHIFTERS!!! what the f*** for!!!!"
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Transfer Twin Sticks, What's the Best? [Re: 4WD22R] #687441 01/20/06 03:10 PM
keep in mind that none of the twin sticks on the market are designed to work with a single t-case.
the straight up shifters will interfere with the transmission shifter.
i had to make one with funky bends in the handle to clear the transmission shifter
Re: Transfer Twin Sticks, What's the Best? #687442 01/20/06 03:39 PM
bkg Offline
When I read your first sentence I wanted to cry foul, but you are 100% correct about shifter interference. Good call. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Brian K. Gallus
Re: Transfer Twin Sticks, What's the Best? [Re: bkg] #687443 01/20/06 04:54 PM
Red_Chili Offline
Toyota Section Staffer
And not hard to do with a MAPP gas torch. Just make sure no plastic parts are still attached. <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
For most of us it's a gadget. Kinda like when I want the car salesman to go away and leave me alone when I stop to get parts:
"Hey, don't you want to get a newer truck? We've got some great new trucks, bet you've got a lot of miles on that one."
"Why would I? Solid axle, 3.4, lockers F&R, ..... , blah, blah, blah, 20 forward speeds, 4 reverse, take a look inside."
He glazes over right about then. Mission accomplished.
-Bill
Re: Transfer Twin Sticks, What's the Best? [Re: Red_Chili] #687444 01/20/06 06:50 PM
Andy Offline OP
So, this buzzing has me a little concerned, I'm told they DO NOT want me to be any more nuts than I already am.<img src="/forums/images/graemlins/cyclops.gif" alt="" />
Loud buzz, minor buzz, did you try to dampen the buzz? I'm running BFG MT's and the road noise is macho loud, plus that NV4500's gear set isn't whisper quiet either.
If the twin sticks interfere with the transmission shifter, I'll make the necessary adjustments.<img src="/forums/images/graemlins/notooth.gif" alt="" />
Real fun takes hard work.
'83 Short bed, NV4500, 33" BFG MT
Re: Transfer Twin Sticks, What's the Best? #687445 01/20/06 08:07 PM
D-runner Offline
That may be true if your running a forward shift t-case. I have a W-56B with a top shift t-case and have no interferance problems with the transmission shifter.
Andy - As for the buzzing sound, it no problem if your driving around town but out on the freeway for an hour and you will go nuts. <img src="/forums/images/graemlins/zombie.gif" alt="" /> When Marlin rebuilt my trans, I asked him about the shifter noise and thats when he showed me the twin sticks that he sells and said that it would be quiet. It has been for the last 3 years.
Chili Man - Don't forget to show them the FF rear axle. Drove my parts man crazy when I told him that I have manual locking hubs on the rear and LC brake parts.
Adam W.
87 4Runner SR5 - 22RE w RV head & TRD Cam, LCE header, W56B-HD, 4" Stage II, 1.5" BJS, Rancho T-bars, F 5.29, R 5.29 ARB V6 FF w LC disks, 35" MT/R's
85 4Runner frame, 5" Marlin springs, 5:29 ARB HP front. Work in progress - Always!
Re: Transfer Twin Sticks, What's the Best? [Re: Andy] #687446 01/20/06 08:17 PM
DirtyHarry Offline
Toyota Moderator
At Chili Man's recommendation I put a wavy washer between the sticks on my FROR twin stick. Unfortunately I cannot tell you if this has helped at highway speeds or not. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Transfer Twin Sticks, What's the Best? [Re: D-runner] #687447 01/20/06 10:39 PM
whose twin stick do you have? i have a w-56 and a top shift as well.
for reference,here is the one i made:
Re: Transfer Twin Sticks, What's the Best? #687448 01/20/06 11:06 PM
Andy Offline OP
I took this quote from Marlin's site:
"Twin shifters can not be used on a single transfer case behind a W56 C or D model transmission but can be used on the rear case of a dual case setup on these transmissions."
I suppose this is because of transmission shifter interference. Apparently A and B versions are OK. I don't have a W56, but am curious as to how many W56 versions there are.
I like the curves, Napoleon!
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6396 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-06-17 04:04:38 UTC
