Page 3 of 3 1 2 3
Re: A few SAS Pictures... [Re: Andy87] #687958 01/26/06 09:57 PM
That is pretty cool. I've always wanted one of the xtra cab longbeds, but they didn't make them 4wd (as far as I know). I had dreams of buying a 2wd and doing exactly what you are one day.
Nice job.
We got them here, extra cab long wheel base 4X4 and diesel too, I've seen an extra cab body on a 4Runner chassis and the rear chopped/bobbed, 3 foot long tray bed, looked the goods, had an SAS with coils up front too
Kev
Re: A few SAS Pictures... #687959 01/26/06 10:05 PM
Red_Chili Offline
Toyota Section Staffer
I have personally seen an XtraCab 4x4 Longbed, 84-88, in Englewood, CO.
-Bill
Re: A few SAS Pictures... [Re: Red_Chili] #687960 01/27/06 08:21 PM
TNToy Offline
His u-bolt spring plates aren't bending because they're too thin. They're bending because they're flat. You can go one of two ways:
* Use a big flat piece of square that's about 1/2" thick. That so thick it probably won't bend, but it's a royal pain to drill through.
* Use thinner stuff and bend the ends up 45 degrees just outside of the u-bolt nuts. I've got 1/4" plate for my u-bolt flips at all 4 corners, and the plates haven't bent at all on a rearend beaten hard enough to crush the tube and bend the housing 5 degrees out of true.
If you're making them youselves, the easiest thing to do is just grind a notch 3/4 of the way through the plate where you want to bend it, stick in in the vise, and beat it over with a hammer. Then just fill in the notch with a welder.
Cut & paste this link to view it, but this 1/4" plate U-bolt flip cost me $25 worth of u-bolts and a little time...
http://www.pirate4x4.com/forum/attachment.php?attachmentid=206176&stc=1
Mounting the rear 13" travel shocks vertically instead of / \ like a lot of people do was also worth the time. Rides soooo much better that way. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: A few SAS Pictures... [Re: TNToy] #687961 01/27/06 09:00 PM
Elbow_Greese Offline OP
I got the spring plates replaced with 3/8 plate (it was easier to do that). They have a *slight* bend, but still very flat - and they are torqued to spec.
I also got the front gusseted, but it probably wasn't that necessary. It's box tube all the way across, and there is gusseting underneath as well.
It's all good though!
With my new tires on, I don't notice any hint of wobble when going over tracks even at 50mph.
Still thinking on what to do for the rear end to help when I carry a load.
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: A few SAS Pictures... [Re: Elbow_Greese] #687962 01/27/06 10:11 PM
toowacky Offline
Congrats, looks nice... I know that's been a long time comin'. You deserve it!
1988 4Runner 22R-E W56
1989 4Runner 22R-E A340
1995.5 Rodeo 3.2L 5spd
Re: A few SAS Pictures... [Re: TNToy] #687963 01/27/06 11:21 PM
Red_Chili Offline
That does not explain why my non-flat 1/4" U-bolt plates from All Pro (since redesigned because of it by the way) bent. No, while bending the ends of the plate helps a little (VERY little), thickening eliminates the problem.
I ended up welding another layer of 1/4" to mine for a total of 1/2" and have had no problems since - despite robust torqueing of 5/8" U-bolts as well.
-Bill
Re: A few SAS Pictures... [Re: Red_Chili] #687964 01/28/06 01:39 AM
SHAD Offline
Good Job.
<img src="/forums/images/graemlins/kewl.gif" alt="" />Welcome to the SAS club.
Looks like it's moving right along are those 33" truxus tires or 35's?
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: A few SAS Pictures... [Re: SHAD] #687965 01/28/06 01:46 AM
They're 33's <img src="/forums/images/graemlins/kewl.gif" alt="" />
Although, I could see 35's on there now too <img src="/forums/images/graemlins/shiner.gif" alt="" />
FWIW, my frame is still just under 22" off the ground
And with weight on the tires, the center of my hubs are just about 16" off the ground.
So, I have a "ride height" of about 6" <img src="/forums/images/graemlins/kewl.gif" alt="" />
Makes it a nice low SAS <img src="/forums/images/graemlins/smile.gif" alt="" />
Todd
94 2wd v6 extracab
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6296 MB (Peak: 0.7416 MB) Data Comp: Off Server Time: 2026-07-09 14:18:35 UTC
