exahust #688006 01/20/06 07:19 PM
toyotaguy55 Offline OP
im looking for suggestion for my exausht size, i was thinking 2" from the cat back? please im need some info if thats good
toyotas look good with body damage
Re: exahust [Re: toyotaguy55] #688007 01/20/06 07:48 PM
Esquire812 Offline
What are ya working with for an engine? Running a header(s) or stock manifold(s) with downpipe?
For 22R-E's I found the stock manifold and factory style downpipe are every bit as good as a header. Plus they require less maintenence (retightening hardware-replacing gaskets). From the cat go with a full 2" ID pipe into a 2-1/4" in/out muffler (I use Holley "Raptors") then exit the system using 2-1/4" ID pipe. Try keeping the bends and turns to minimum for best flow and performance.
Just my $.02 maaaaaan......
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: exahust [Re: toyotaguy55] #688008 01/20/06 07:51 PM
4Crawler Offline
I run 2" on my '85/22RE and it works well:
- http://www.4crawler.com/4Runner.shtml#Engine
Re: exahust [Re: Esquire812] #688009 01/20/06 08:04 PM
I agree with the 2.25. for me it didnt add much if any power, but it did open up the RPMs and helped the engine run much smoother in the high RPMs.
JG
Re: exahust #688010 01/20/06 09:01 PM
i figure a 2"because my bender can do that, and a flow master 80, should do me fine
Re: exahust [Re: toyotaguy55] #688011 01/20/06 09:04 PM
4Crawler Offline
I chose 2" for similar reasons. I had almost all the material on-hand since I put the same size exhaust on my VW. And it was easier to run 2" since I could fit it between the body and frame with a 1" body lift. Now I could run a larger exhaust, but 2" works fine for me.
Re: exahust [Re: Esquire812] #688012 01/20/06 09:46 PM
Rauch_Off_Road Offline
x2 if you can swing it.
(aka suprathepeg, aka Sean)
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6142 MB (Peak: 0.7077 MB) Data Comp: Off Server Time: 2026-07-15 04:37:12 UTC
