Need advise on shocks
#688019
01/20/06 07:25 PM
Hello I have stock 88 montero right now and will be doing 2" lift by cranking t-bar and adding a leaf made by ProComp. I noticed few sites are recommending KYB shocks. But I was told by KYB that their shock isn't designed for suspension lift trucks. I'm wondering if anyone is using KYB shocks w/ lift? Part # I have from summit racing for KYB shocks are KYB-KG4034(rear) and KYB-KG5603A(front). If you don't recommend KYB what shocks are good to go with? Thank you
88 Montero 2.6L 2" Body Lift 32" Geolanders
Re: Need advise on shocks
[Re: TrooperMonty]
#688020
01/20/06 10:17 PM
The part numbers are around somewhere for KYB's that are for lifted Montero's. Sorry I don't have them as I'm stock.
Two inches is a lot for the torsion bars, have you thought about a body lift?
[Re: LRJ4x4]
#688021
01/21/06 01:39 AM
I thought several of Gen1 montero owners lift 2" by cranking torsion bar? What's maximum I can lift without damaging IFS?
[Re: TrooperMonty]
#688022
01/27/06 05:52 PM
1 1/2 to 2" can be obtained. MIght need to trim the rubber on the bump stop. Longer shocks are not needed. If you off road, I recommend the very soft "Red Rider Comfort" shocks.
[Re: TrooperMonty]
#688023
01/27/06 05:55 PM
I've been told KYB rep in my country that KYB shocks (Gas-A-Just series) are *very* stiff, and are meant for street performance, not off-roading. Probably the MonoMax series are better suited for off-roading.
I just installed ProComp ES9000s on my truck and I'm very satisfied with their perfomance, on and off-road. These are meant for up to 1" lift tough.
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6069 MB (Peak: 0.6714 MB) Data Comp: Off Server Time: 2026-06-19 04:02:53 UTCValid HTML 5 and Valid CSS
