changeover 2WD to 4WD--2000 Rodeo??? #688098 01/20/06 09:39 PM
E
EricsTJ Offline OP
This might be crazy ,Guys, but has anyone ever done a changeover from 2WD to 4WD on a 2000 rodeo 5 speed 3.2?
I have already priced a used 5 speed tranny with transfer case, but really need to know if I would need to consider more than the Tranny/transfer,Front Diff,both LH and RH axles,front hubs,front driveshaft, and probably a different length rear driveshaft.?
I would assume that all the mounting points would already be there,and it would be a matter of fitment ,and a lot of time......
Let me know if I am crazy,and just need to sell the 2WD and find another 4WD....I don't mind a little work..Thanks...
1997 Wrangler TJ 5 speed, 2.5 L. Mostly stock except for 31x10.50's on Black Rockcrawler Rims.
1998 Wrangler TJ 5speed, 4.0L. Rusty's 3.5 " lift,33"BFG,4.10 gears,Novak transfer case shifter
Re: changeover 2WD to 4WD--2000 Rodeo??? [Re: EricsTJ] #688099 01/20/06 09:57 PM
TrailMystic Offline
I'm pretty sure everyone on the board will tell you to sell the 2-wheel drive and buy a 4-wheel drive. It's a costly and difficult conversion. There are no dumb or crazy questions. You're doing your homework and I commend you. This board is a great souce of info.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: changeover 2WD to 4WD--2000 Rodeo??? [Re: TrailMystic] #688100 01/20/06 11:16 PM
Troopersphere Offline
I bet not as many as you might think Pete!
Yes, it's a little work, but a good candidate for SAS !
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: changeover 2WD to 4WD--2000 Rodeo??? [Re: Troopersphere] #688101 01/21/06 02:53 AM
TrooperJ Offline
Im pretty sure the front a-arms for the 2wd are different than the ones for the 4 wheel drive. I also agree that the general consensus is to just buy a 4wd truck to start with. Especially with that new of a truck. It would be alot easier if you were going with SAS, but its going to be alot of work, either way.
-J <img src="/forums/images/graemlins/kewl.gif" alt="" />
Oh yeah, these blue links....money saving feature? Kindof annoying, but if it helps out the wire....its ok with me, i guess. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
Re: changeover 2WD to 4WD--2000 Rodeo??? [Re: TrooperJ] #688102 01/21/06 03:56 AM
CPOM Offline
Don't forget the 2000 is going to have air operated solenoids and electronic controls necessary to engage the 4wd that are a little bit more complicated than just bolting on a bunch of components. Wiring harnesses and tubes etc.
Migiht want to also check wether the ecm has any say in 4wd engagement. I know the system is smart enough not to let you engage it without going slow enough.
CHRIS
98 Amigo, 92 Pup
Re: changeover 2WD to 4WD--2000 Rodeo??? [Re: CPOM] #688103 01/21/06 04:19 PM
E
EricsTJ Offline OP
Thanks Guys--any input is appreciated--I haven't even thought of ECM,etc..
I might be leaning toward finding a 4WD...Don't really want to SAS on one this new...
Re: changeover 2WD to 4WD--2000 Rodeo??? [Re: TrooperJ] #688104 01/21/06 04:22 PM
Richard Saylor Offline
Glad I'm not the only one seeing those. Thought I was going nuts there for a while .... <img src="/forums/images/graemlins/lol.gif" alt="" />
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: changeover 2WD to 4WD--2000 Rodeo??? [Re: Richard Saylor] #688105 01/22/06 05:08 PM
BobDole Offline
OT- I don't see those blue links. I think you guys have some crappy software that installed itself. <img src="/forums/images/graemlins/frown.gif" alt="" /> /OT
I would say definitely sell the 2wd and get another 4wd. You may be attached to the truck now, but when it's torn up and you're stuck, out of money and frustrated, it wont be so endearing. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: changeover 2WD to 4WD--2000 Rodeo??? [Re: BobDole] #688106 01/22/06 06:29 PM
TrooperJ Offline
The admins decided to take the blue links out, cause they were linking to Irrelevant information. They really were there. Look on the yota off topic boards where they are discussing it.
Back to the regularly schedualed Zu-talk.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6284 MB (Peak: 0.7328 MB) Data Comp: Off Server Time: 2026-11-02 19:28:21 UTC
