Which brand gear oil? #688109 01/21/06 12:03 AM
I'm going to change the gear oil in my front and rear differentials in my 85 trooper soon but I don't really know that much about gear oil. Which brands do yall think are the best? More than likely I'll go synthetic unless its not worth the extra money. I need 75w 90 for the front and 80 w 90 for the rear and I was wondering if I could just use the 80w for both. Would it cause any problems?Also, I don't know if I need to add the limited slip stuff or not, do I?
Re: Which brand gear oil? #688110 01/21/06 12:33 AM
Gizzy42 Offline
I used Valvoline SynPower in both the front and rear diffs on mine. I just used the same weight in both 75w90 is fine to use in both of them. It also has LSD additives in it so you dont have to mix if you have LSD. If you dont it wont hurt anything.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Which brand gear oil? #688111 01/21/06 01:43 AM
Tom_G Offline
If you don't have limited slip, you certainly don't need any additives.
I used Mobil1, but some have said (and I kind of agree) that synthetic is less valuable in non-combustion applications like differentials, transmissions and t-cases. Mobil1 in my transmission certainly made the shifting smoother.
If you go synthetic, you won't have a lot of choices with regard to viscosity. I don't think you'll find 80W90 synthetic. Even with the out of spec viscosity, the synthetics will work fine.
I'm kind of a synthetic nut--I even use synthetic grease in my wheel bearings and keep synthetic grease in my grease gun. My Trooper has been 100% synthetic for quite a while, and I'd like to think it's worth the (minor) added expense.
1995 Trooper S
5 Speed
Bone Stock, for now...
It's better to regret something you did
Than something you didn't do
--Michael Balzary
Re: Which brand gear oil? [Re: Tom_G] #688112 01/21/06 02:00 AM
ProBMXer1313 Offline
Same here pretty much, all Mobil 1 synthetics in my Passport.
1998 Honda Passport EXL V6 3.2L Auto SOTF 4WD
3" Calmini Lift w/ HD Track Bar, 32x11.5-16 Super Swamper SX, Aisins
[color:"blue"]http://www.CarDomain.com/ID/ProBMXer1313[/color]
Re: Which brand gear oil? #688113 01/21/06 02:35 AM
holger Offline
I've not heard of any differential failure due to "bad" gear oil brand. Whatever is approved by SAE is OK.
But I personally use full-synthetic RedLine fluids everywhere around the car. I only use Mobil1 (as a cheap solution <img src="/forums/images/graemlins/smile.gif" alt="" /> ) as the engine oil, everything else is RedLine.
Oleg
Deceased Rodeo'02 4WD.
Re: Which brand gear oil? [Re: holger] #688114 01/21/06 03:49 AM
strawmyers Offline
Isuzu Moderator
I use Mobil 1 in my rear diff only because of the ARB. Before that, I used the cheapie Coastal or other store brand (which is what I still use in the front). IMHO, its not worth dropping any extra coin on a stock diff. The 'average' vehicle owner probably never even changes diff fluid and how many people do you know that have had R&P failure?
Sean Strawmyer
Re: Which brand gear oil? [Re: strawmyers] #688115 01/21/06 10:52 AM
CPOM Offline
what ever is cheapest
CHRIS
98 Amigo, 92 Pup
Re: Which brand gear oil? [Re: CPOM] #688116 01/21/06 01:18 PM
Mike Bridges Offline
I'll second the what ever cheapest. It made it 20 years without it.
Re: Which brand gear oil? [Re: Mike Bridges] #688117 01/21/06 01:44 PM
Sammy Offline
I'll third that. Has anyone here ever 'worn out' a propery set up ring and pinion?
Sammy
95.5 Rodeo, automatic, 3.2 SOHC, D44 front and rear, 4.88's, 33" muds
Re: Which brand gear oil? [Re: Sammy] #688118 01/21/06 06:13 PM
8
800XL Offline
Never worn gears out, but I have gone through a few seals here and there. If I was going to be concerned with something it would be preserving the seals the best way possible, not wear on the gears.
"Time and tide melts the snowman"
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6360 MB (Peak: 0.7589 MB) Data Comp: Off Server Time: 2026-07-13 21:17:24 UTC
