Re: Engine swap question
[Re: valleycat]
#688413
01/27/06 03:12 AM
I didn't notice the wrangler comment, sunder is right on that part, the 225 was 63 to 71 with the exception of 66 in the cj's.
#688414
01/28/06 05:08 AM
If the Jeep originally had a 2.5L, then the 2.8L V6 will bolt up to the Jeep AX5 tranny with the stock 2.5L bellhousing. You'll have to use the 2.8L flywheel. If the Jeep originally had a 4.0 in it and still has the AX15 tranny, then you'll have to use a 96-00 Dodge Dakota 2.5L bellhousing and a Camaro flywheel. Probably not worth all of this effort.
Greg
[Re: cuervo25]
#688415
01/28/06 09:13 AM
i agree with valley and sunder on this compleatley. i belive it was a ford designed engine that both jeep and gm used.they were terrible engines the didnt last long before stuff went. tell your friend he may be better off with a 4.3 if the bolt pattern is the same on the trans as the 2.8. This is the same engine as used in late 80's early 90's CHev Lumina and Beretta. Guy i knew took a 2.8 out of his XJ and dropped it in his Beretta, said it was a direct bolt on. Yeah right <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.5940 MB (Peak: 0.6645 MB) Data Comp: Off Server Time: 2026-10-21 16:19:04 UTCValid HTML 5 and Valid CSS
