Engine Break-in oil question... #688616 01/22/06 08:43 PM
84toyota Offline OP
Getting ready to break-in my new 22r rebuild... I have some quaker state 5w30 oil that I want to get rid of - because I don't care for quaker state, and I don't really need 5w30 where I live... would it be ok to use this oil in my first round of oil changes when breaking in the new motor? Is there a preferred oil to use during initial break-in? Does it really matter what oil you use considering the short duration that it will be in the engine before changing it out?
Thanks,
Ken
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: Engine Break-in oil question... [Re: 84toyota] #688617 01/22/06 10:02 PM
engnbldr Offline
>>>*I wouldn't be concerned at all. About the only oil I won't use during breakin is synthetic.....*EB
*Beats the he** outa me!....*LOL**...
Re: Engine Break-in oil question... [Re: engnbldr] #688618 01/22/06 11:37 PM
kyle-22r Offline
i used 5w30 for the first 200 miles or so on my new engine. it was a constant reminder to change it out -- it really made my valves tick badly.
i run 10w40 year round, works the best in my experience.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Engine Break-in oil question... [Re: engnbldr] #688619 01/23/06 01:38 AM
TimsToyo Offline
I've heard that from a lot of different people but can't seem to get a consistent reason why. What's the reason you don't run synthetic oils during break-in? Ring seating?
'86 Toyo 4wd
'04 600RR
Re: Engine Break-in oil question... [Re: TimsToyo] #688620 01/23/06 03:53 AM
becuase it's too dang good at preventing wear.
there are more than a few that say the rings and bearings won't run in right unitl they got some solid wear between everything. that bieng said, every new corvette is delivered from the factory with Mobil 1 synthetic in the crank case. personally, I ran the first 20 minutes on my new motor with non-synthetic.
Re: Engine Break-in oil question... #688621 01/23/06 06:48 AM
Jiingwon Offline
For breaking in my 22R, I just used the cheapest 10W30 I could find. Worked for me!
-Darren
'84 Xtra Cab Sold <img src="/forums/images/graemlins/frown.gif" alt="" />
'96 Tacoma in progress <img src="/forums/images/graemlins/smile.gif" alt="" />
God forgives...rocks don't.
Re: Engine Break-in oil question... [Re: 84toyota] #688622 01/23/06 07:32 PM
Esquire812 Offline
Valvoline 10w-30 (non-synthetic) everytime! But Im kinda anal that way ya know. Take it through the revs while checking for leaks and funny noises all the while keeping an eye on temperature readings. Shut her down after a good 20 minutes and change the filter and top off coolant and oil. Drive it a good 500 miles varying your RPMs, do a few hills with the engine under load and then do a full oil and filter change, recheck valve settings and retorque the head bolts just for GP's. Should last ya along time and keep a smile on your face.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Engine Break-in oil question... #688623 01/23/06 09:30 PM
Red_Chili Offline
Toyota Section Staffer
IF the new motor is built for synthetics with extremely tight tolerances and IF the manufacturer says so, sure, gopher it. For all else, I'd put at least 1500-3000 miles on it following Darin's regime before putting synth in. Rings won't fully seat for a very, very long time. Which itself is pretty powerful testimony for the value of synth oil.
I run DuraBlend because I'm cheap and I still want to change the oil often to remove contaminant fluids.
-Bill
Re: Engine Break-in oil question... [Re: 84toyota] #688624 01/24/06 01:04 AM
My dad uses straight 30w oil to break-in his engines, then he switches to a multi-viscosity oil, I've never seen him use 100% synthetic oil though, usually because the engines have a short life on the track.
Re: Engine Break-in oil question... [Re: 84toyota] #688625 01/24/06 01:06 AM
P
pugski1043 Offline
About how long does it take for an engine to " break in". Once the rings are seated should MPG's improve?
1994 Toyota Pickup 22RE, EB 268 cam , 2.25 LCE exhaust.
1988 Toyota 4Runner, mostly stock but hopefully not for long
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6388 MB (Peak: 0.7623 MB) Data Comp: Off Server Time: 2026-05-29 22:30:58 UTC
