Will 6 lug yota rims work? #688850 01/23/06 09:00 AM
allsierra123 Offline OP
A friend of mine just gave me a set of 6 lug rins of his toyota anyone know if they will work for my truck?
91 Mitsu Montero RS LWB PENDING
88 Cherokee Lifted and modded heavily. FOR SALE
91 vanagon syncro 1.9 TD SOLD
04 Suzuki Aerio Commuter SOLD
90 mits mighty max,v6 SOLD
94 Mits Diamante LS. Stock. TOTALED
71 VW Baja Bug SOLD
Re: Will 6 lug yota rims work? [Re: allsierra123] #688851 01/23/06 01:39 PM
If the center hole is 4.125" or more.
Re: Will 6 lug yota rims work? [Re: fasteddy] #688852 01/23/06 06:40 PM
They look to be,but i didnt measure for sure.Im goin over to try them out sometime this week.Now i have to figure out what to do with my 15's and the tires.
71 VW Baja Bug SOLD
Re: Will 6 lug yota rims work? [Re: allsierra123] #688853 01/24/06 12:10 AM
photoduo Offline
Check out the link for wheel bolt hole pattern sizes.. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Wheel Bolt Patterns
Astoria, Oregon Coast
1987 Dodge Raider
Re: Will 6 lug yota rims work? [Re: photoduo] #688854 01/24/06 07:28 AM
that link worked out great.They all matched up except for one.It was the CB column,The mitsu had none listed and the yota rims said 108??Any ideas what that means?
71 VW Baja Bug SOLD
Re: Will 6 lug yota rims work? [Re: allsierra123] #688855 01/24/06 08:08 PM
franklynberry Offline
I run 6 lug 4Runner rims on my '88 Gen I, off a 97 'yota, I think. 16" x 7" wide with 4" backset. Fit fine with 265/70-16" Dunlops.
Takes a 12mm 'shoulder' style nut; got 'em at NAPA, using the 4Runner listing.
--frankb
'88 SWB 5-speed Megasuirt MS-II V3 Starion TBI N/A 650/950cc Injectors 4Runner Alloys 275-70R16
Re: Will 6 lug yota rims work? [Re: franklynberry] #688856 01/24/06 08:49 PM
Good deal.Now to get rim of my 15's.I have nowhere to store them anyone think I should put them on ebay?
71 VW Baja Bug SOLD
Re: 15" rims ? [Re: allsierra123] #688857 01/25/06 06:14 AM
What combo are you running on the 15" rims? Where along the Sierra Nevada's are you?
Re: Will 6 lug yota rims work? [Re: allsierra123] #688858 01/25/06 06:33 AM
Probably 108mm's.
I believe the problem is this tells you the minimum center bore that will fit a toy. It's the bore of the actual rim you need to know.
--frankb
I'd assume that the lug nut spec's aren't as important for his situation since it's the rim we're looking at right? or maybe I'm missing something <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: 15" rims ? [Re: rxinhed] #688859 01/26/06 01:38 AM
The rims are 15x10 i beleive and the tires im running are a 32x11.50.Im in oakhurst by the south entrance of yosemite.
71 VW Baja Bug SOLD
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6387 MB (Peak: 0.7621 MB) Data Comp: Off Server Time: 2026-06-21 09:55:47 UTC
