wheel backspacing with toyota IFS #688943 01/23/06 09:18 PM
maxxis85 Offline OP
I was wandering if i can run my 4" backspaced rims on my 1989 toyota pickup. I am putting a 4" trailmaster kit (used)and was wandering what to do. trailmater says not to exceed 3.75" and superlift says 4.5". I dunno, i figured someone on here had the same experience and can help me out.
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
Re: wheel backspacing with toyota IFS [Re: maxxis85] #688944 01/23/06 09:26 PM
4Crawler Offline
You could always try it, or add a 1/4" wheel spacer if needed (4"-.25"=3.75"). The different lift kits probably have slightly different designs of the steering knuckle and other parts that account for the backspacing differences.
Re: wheel backspacing with toyota IFS [Re: maxxis85] #688945 01/23/06 10:01 PM
jcssurf Offline
What size wheel?
If it's a 15x10 and you're planning to run a 12.50 tire, I'm 99% you'll be fine, but a 15x8 would probably be too close.
They are just trying to make sure your tire doesn't contact the knuckle adapter. I know of people running 12.50 tires with those lifts on 15x8s with 3.75 BS and it's close. But also ones running 10.50s on a 4.5 BS wheel that clear. A 10 inch wheel leaves less sidewall on sides and that's why I'm pretty sure it would work.
But, like Roger said, if not, you could always do a small spacer.
90 pickup, 22RE, stiff-ass Ranchos, 2.25 catback, 4:1 header, conical intake, 15x7 ICW alloys, 32x11.50 Dunlop Mud Rovers, 4.56s w/v6 rear
-Farm truck until school is done...then plans
2000 Honda CRV EX 5 speed
-Driver
Re: wheel backspacing with toyota IFS [Re: jcssurf] #688946 01/23/06 10:10 PM
eightyeight Offline
my '88 has a 4" trailmaster. with stock tires (235/75r15) and stock rims, the tire hit the tie-rod end.
however, the same wheels and tires did not rub on my buddy's truck with a 4" superlift.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: wheel backspacing with toyota IFS [Re: eightyeight] #688947 01/23/06 10:58 PM
maxxis85 Offline OP
I got 15x8 american racing tailgunners with 4" of backapacing.
I got a 3" bl now and i plan on running a 36x12.50 tsl swamper. i hope they work.
Re: wheel backspacing with toyota IFS [Re: maxxis85] #688948 01/24/06 03:27 AM
jcssurf Offline
I'd try the tires without the IFS lift first. With some trimming you should definitely be able to make them work with what you have and save the money for gears.
If not, you can add the IFS and lower the T-bars for a better ride.
-Driver
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6110 MB (Peak: 0.6809 MB) Data Comp: Off Server Time: 2026-06-09 23:29:08 UTC
