4runner
#689396
01/25/06 01:39 AM
I am new to this forum and I am buying a 2002 4-runner to go wheeling in. What are some cheap mods to get it trail ready? I'm not afraid to trim the fenders to fit a larger tire. What is the largest tire I can fit that way. Also, I heard there is an easy way to lift it 3" with the torsion bars? I have a 72' Bronco that is slowly turning into a show truck, and I'm getting the 4-runner to scratch my off-road itch. Thanks for the help, Craig
Re: 4runner
#689397
01/25/06 03:42 AM
Welcome to the forum.
The best mod by far is a locking rear differential. There are many options to choose from, from fulltime locking diff to a selectable manual locker.
FYI a 02 4Runner does not have torsion bars. You have a coilover shock/spring instead. You will want to keep the lift under about 2.5", otherwise you will max out your ball joints. I'd suggest a differential drop at the same time you do the lift to relieve your CV boots to make them last longer. I'd go with a cornfed spacer lift if you want cheap and easy. Otherwise, go with some OME (Old Man Emu, from ARB) springs and shocks.
Re: 4runner
[Re: Adam F]
#689398
01/25/06 04:28 AM
FYI a 02 4Runner does not have torsion bars. You have a coilover shock/spring instead. You will want to keep the lift under about 2.5", otherwise you will max out your ball joints. I'd suggest a differential drop at the same time you do the lift to relieve your CV boots to make them last longer. I'd go with a cornfed spacer lift if you want cheap and easy. Otherwise, go with some OME (Old Man Emu, from ARB) springs and shocks. Do you have any info on the cornfed spacers lift? I just want to go cheap... What about the tire size also. Thanks for your help. Craig
Re: 4runner
#689399
01/25/06 03:57 PM
There is some very good information about different lift options here: http://www.4x4wire.com/toyota/4Runner/tech/suspension/ a review about the spacers found here: http://www.4x4wire.com/toyota/4Runner/tech/suspension/phil.htm"On-road this setup is pretty good but it has stiffened up the truck a bit too much. You do feel the bumps. Off-road the added height helps along with the 33" tires. Articulation is very limited. Stiffness and lack of articulation is due to the spacer/spring combo, too much preload of the progressive rate springs." He fit 285/75/R16 with the 1.5" spacers. it is definitely the cheapest way to go.
Re: 4runner
[Re: themainjam]
#689400
01/25/06 08:49 PM
Phil had the spacers combined with the progressive springs, which is a no no. This combo will significantly stiffen the ride. If you put spacers on STOCK springs, you will retain the factory ride. The cornfed website is here http://www.cornfedsuspension.com/285/75/16 is the ideal tire.
Re: 4runner
[Re: Adam F]
#689401
01/26/06 12:41 AM
Thanks for the help, I'll look into the lift. I appreciate the suggestions. Also what are some other good 4runner forums on the web. Thanks, Craig
Re: 4runner
#689402
01/26/06 12:56 AM
