air bag light #689596 01/25/06 08:12 PM
twholland Offline OP
Anybody had any issues with airbag warning light staying on. I started my truck one day, the light lit up like normal (system check), but never went out.
'97 T100 XCab 4X4 SR5, 3" BL, 33x12.5 BFG A/T, Warn hubs, Ranchos
Re: air bag light [Re: twholland] #689597 01/27/06 04:00 AM
garym Offline
I don't know how far you want to get into it but..The light has 12V to it from the ECU-B 15A fuse so any ground will kick that light on. It goes to a connector then to the airbag sensor assy behind that plastic piece over the center hump on the dash. From there it looks like there is a LH and RH airbag sensor that could go to ground or it could be in that sensor assy. There are 3 other inputs to that sensor. +12V through the 15A cig lighter fuse, +12V from the 7.5A ign fuse, and a wire to the data link connector under the hood. You might check those fuses. Depending on your milage it may be under warranty. If they cover the seatbelts to 100K, they should cover that. If you want me to look further into the drawings, let me know.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: air bag light [Re: twholland] #689598 01/27/06 04:28 AM
J_Bird Offline
Mine's done the same thing. I cant fix it. Just learned to live with it. Let me know if you find something!
Re: air bag light [Re: twholland] #689599 01/27/06 01:08 PM
Squeezer99 Offline
the factory service manual lists the proceedure for diagnosting the SRS warning light. on my manual it starts on page rs-34. If I were you, i'd purchase the service manual set from toyota publications and diagnose the system and fix what the manual says is wrong following the diagnostic steps.
Re: air bag light [Re: twholland] #689600 02/01/06 07:22 AM
Kookadala Offline
You could always wack the front bumper with a large sledge and see if the airbag deploys!! <img src="/forums/images/graemlins/nana.gif" alt="" />
Isnt the little black box mounted on the passenger inner fender along side the airfilter box the airbag sensor?
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: air bag light [Re: twholland] #689601 02/01/06 08:57 AM
kewlynx Offline
You guys can start by disconnecting your negative battery terminal for 90 seconds; see if the light goes out (yes, recommended procedure); troubleshoot/inspect from there if the light continues to stay on.
**ubi apis- ibi salus**
Re: air bag light [Re: kewlynx] #689602 02/02/06 04:58 PM
i disconnected my negative battery terminal for a couple of minutes and wiggled some wires/connectors around on the sensors and light is still on. It'll be on for awhile i guess.
Re: air bag light [Re: twholland] #689603 02/03/06 02:42 AM
kewlynx Offline
We have a manual sticky'd over in the Runner section; might see if there's an airbag section over there, or at least in the electrical section for troubleshooting.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6212 MB (Peak: 0.6997 MB) Data Comp: Off Server Time: 2026-10-30 10:19:38 UTC
