why does the 05 tacoma have more horsepower #689735 01/26/06 01:10 AM
why does the 05 tacoma have more horespower and torque
than the 06 tacoma?
2005 tacoma 245 hp and 282
2006 tacoma 236 hp and 266
Re: why does the 05 tacoma have more horsepower #689736 01/26/06 01:25 AM
Marc M Offline
They did the ratings on the '06 using lower octane fuel, or so that's what I heard.
Marc
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5/TRD....
'90 4Runner 4X4 SR5 5-Spd
'86 Shortbed 4X4 5-Spd, SAS'd ASAP
'82 Supra 5-Spd
Take your automatic and "Stick" it........
My Web Album in Progress
Re: why does the 05 tacoma have more horsepower [Re: Marc M] #689737 01/26/06 07:18 PM
hupptoy Offline
Actually, they changed the way the ratings are measured. Back in the 60's, the HP rating was *gross*, and then in 1972, it went to *net* (as determined by S.A.E. Standard J1349) which lowered the rating for most engines and in 2005 *SAE-certified* (SAE J2723) same into being (but only on a voluntary basis) which lowered most (although some did go up) vehicles actual rating even though the engine did not change.
Here is a quaote (from http://en.wikipedia.org/wiki/Horsepower#SAE-certified_horsepower ):
SAE-certified horsepower
In 2005, the Society of Automotive Engineers introduced a new test procedure (J2723) for engine horsepower and torque. The procedure eliminates some of the areas of flexibility in power measurement, and requires an independent observer present when engines are measured. The test is voluntary, but engines completing it can be advertised as "SAE-certified".
Many manufacturers began switching to the new rating immediately, often with surprising results. The rated output of Cadillac's supercharger Northstar V8 jumped from 440 hp (328 kW) to 469 hp (350 kW) under the new tests, while the rating for Toyota's Camry 3.0 L 1MZ-FE V6 fell from 210 hp (157 kW) to 190 hp (142 kW). The first engine certified under the new program was the 7.0 L LS7 used in the 2006 Chevrolet Corvette Z06. Certified power rose slightly from 500 hp (373 kW) to 505 hp (377 kW).
Hope that helps.
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: why does the 05 tacoma have more horsepower [Re: hupptoy] #689738 01/26/06 08:04 PM
so you are saying that the engines have the same horsepower but are just rated different because of a new different standard? thanks for the reaply <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: why does the 05 tacoma have more horsepower #689739 01/26/06 08:14 PM
I wander why the 05-06Frontier is still pumping out so much HP and Torque... i wish my tacoma had 265 horses and 285 lb-ft torque that would be nice pulling my boat. but again if it did then i would just want it to have 300 hp and 350 lb-ft torque <img src="/forums/images/graemlins/smile.gif" alt="" /> i thought about getting a tundra when i got my new tacoma just for that extra horsepower and torque but i just like the new tacomas so much better than the tundras
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5978 MB (Peak: 0.6631 MB) Data Comp: Off Server Time: 2026-06-07 07:16:55 UTC
