motor swap and now auto trans won't kickdown to passing gear #689740 01/26/06 01:13 AM
had a friend swap an 89 4runner motor to my 87 4runner. both are automatic. he is not familiar with auto trans. now trans won't down shift to passing gear. also, it seems to shift too quick when accelorating. we think that it may be a linkage or elec. problem. any help would be appreciated
Re: motor swap and now auto trans won't kickdown to passing gear #689741 01/26/06 04:56 AM
Adam F Offline
Shift solenoids possibly. check out the online FSM
http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
97 4R, stock, daily driver
Re: motor swap and now auto trans won't kickdown to passing gear [Re: Adam F] #689742 01/26/06 06:56 AM
thank you for the reply. i will check it out tomorrow
downloaded the 85 fsn and got all the info.
hope it will help <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: motor swap and now auto trans won't kickdown to passing gear #689743 01/26/06 03:45 PM
mt_goat Offline
Did you use the 89 ECU and the 89 tranny or the 87 ECU with the 89 tranny or the 87 ECU with the 87 tranny or...?
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: motor swap and now auto trans won't kickdown to passing gear [Re: mt_goat] #689744 01/27/06 09:10 PM
we used the 87 ECU with the 87 trannny
is that a problem?
thanx <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: motor swap and now auto trans won't kickdown to passing gear #689745 01/28/06 04:42 AM
mt_goat Offline
Well it would be a place to start trouble shooting. It would be best to use the ECU, engine and tranny (especially an auto) from the same year. I'd look into whether or not anything changed from 87 to 89. If nothing else maybe a sensor or wiring change.
Re: motor swap and now auto trans won't kickdown to passing gear [Re: mt_goat] #689746 01/28/06 06:58 AM
Manson Offline
Don't forget about the tv cable adjustment. This being missadjusted could cause all those problems.
Re: motor swap and now auto trans won't kickdown to passing gear [Re: mt_goat] #689747 01/29/06 05:51 PM
thank you!
i am pulling the tranny and many other parts from the 89.
i may have to put the new tranny in the 87. anyway, the 89 only has 116k and the 87 has 212K.
the throtle postion sensor was bad and the mechanic put a brand new one on. my friend looked at it yesterday and when i told him it was changed, he said that it has to be that adjustment, because it is sending the wrong info to the ecu.
i will let you know what happens. thanx!!!! <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: motor swap and now auto trans won't kickdown to passing gear [Re: Manson] #689748 01/30/06 02:40 AM
problem solved!!!
we adjusted the throtle position sensor and now we have kick-down
throtle position sensor was adjusted in the wrong direction.
thanx to all who replied. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6193 MB (Peak: 0.7049 MB) Data Comp: Off Server Time: 2026-06-07 11:37:17 UTC
