Suspension lift...how much can I lift? #690505 01/27/06 03:51 PM
TrooperMonty Offline OP
Hi guys
I want to lift my monty and from previous post someone told me I shouldn't crank T-Bar 2" as it's too much. I did 3" lift on my 91 trooper and it torned cv boots. I know some of you done the suspension lift and wondering how much you guys lifted and what is recommended height?
Jin
88 Montero 2.6L 2" Body Lift 32" Geolanders
Re: Suspension lift...how much can I lift? [Re: TrooperMonty] #690506 01/27/06 05:12 PM
BobShaw Offline
Somewhere in the 1 1/2 to 2" range is OK.
You might need to trim down the rubber on the lower bump stops too. I removed my lower bump stops completely for off roading. Do you have lock-out hubs or full time hubs?
Full time will wear the CV and Boots faster. Do you have rear leaf spring or coils?
Re: Suspension lift...how much can I lift? [Re: BobShaw] #690507 01/27/06 05:57 PM
I just bought aisin hubs from ebay to replace factory auto hubs and it has leaf spring which I'm going to add a leaf from summitracing made by procomp. One of the article from forum saying that add a leaf is better than longer shackles...
Re: Suspension lift...how much can I lift? [Re: TrooperMonty] #690508 01/27/06 07:13 PM
powerRam50 Offline
i just put the longer shackles on at the beginning of the month and so far i realy like them.also the lower bump stop is not the problem it is the upper's.there are 2 per side for the upper bump stops.and the aisin hubs are thought to be the best.the auto hubs suck,and the aisin's are stronger than the superwinch.but i have never had a problem with the superwinch.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6569 MB) Data Comp: Off Server Time: 2026-06-23 01:18:55 UTC
