Installing a Lock-Right in a V6 4 Pinion Rear #690935 01/29/06 01:06 AM
87Toy4x4 Offline OP
unlike installing a lockrite on a 2 pinion axle, dont i have to take apart the carrier and reset the backlash b/c its 4 pinion?
Re: Installing a Lock-Right in a V6 4 Pinion Rear [Re: 87Toy4x4] #690936 01/29/06 01:51 AM
V
Voyager Offline
Yes, you still have to remove the ring gear & carrier and set backlash. The difference in the 4 pinion is that you don't have to separate the ring gear to install the locker. You can get pretty close to keeping the same backlash by just marking the positions of your tabs & counting threads.
Sid
89 extra cab 4x4 3.0 5 spd, 216K
4.56, Supra LSD, Lock Rite
Re: Installing a Lock-Right in a V6 4 Pinion Rear [Re: Voyager] #690937 01/29/06 04:41 AM
kyle-22r Offline
a dial indicator and magnetic base make things a lot easier. figuring out zero preload is a wee bit tricky, but not too bad. you don't need any extra preload on the carrier bearings if they're already broken in, according to the FSM.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Installing a Lock-Right in a V6 4 Pinion Rear [Re: kyle-22r] #690938 01/31/06 11:59 PM
5
5VZ Offline
Or just mark the adjuster rings and put them back in the marked position.
94 4Runner, 5VZ-FE, A340H
Re: Installing a Lock-Right in a V6 4 Pinion Rear [Re: 5VZ] #690939 02/01/06 03:29 AM
ZUK Offline
5VZ is right on.....just mark the adjusters.....remove case....take bolts out for case halves....install locker...torq case halves together....install case into 3rd and push the ring gear right up against the pinion.....install the ring side adjuster and screw it by hand all the way tight and you will see your mark is just a little past where it needs to be so back the adjuster off until it lines up where it needs to be.
Screw the other adjuster on and you may need a tool to make that mark line up. there ya go.
Now....now is the perfect time to crank some carrier bearing pre-load into those worn bearings....this will have the effect of increasing the ring and pinion strength due to less ring deflection. So simply tight each adjuster 2 or 3 holes and done. Adjust each one the exact amount....well, exact is not really that critical....but close to exact and there ya go <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: Installing a Lock-Right in a V6 4 Pinion Rear [Re: ZUK] #690940 02/01/06 04:21 PM
ZUK Offline
How'd it go? Oh ya....and don't forget tp rap on the bearing cap tops to help equalize/centralize the case between the tensioned bearings. D that with the 2 big bolts only 1/4 turn loose to let the races move around a little.....but don't hit them toooo hard. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
mostly stock
Re: Installing a Lock-Right in a V6 4 Pinion Rear [Re: ZUK] #690941 02/01/06 07:10 PM
87Toy4x4 Offline OP
alright thanks. but does anyone have any pics of a 4 pinion lockright b/c i swear mine is missing parts. there are only 4 pieces, two big ones and two rings that go inside. they didnt even give me springs. im pretty sure it should of came w/ them.
Re: Installing a Lock-Right in a V6 4 Pinion Rear [Re: 87Toy4x4] #690942 02/01/06 07:57 PM
ZUK Offline
I think you're missing the springs and that's all.
mostly stock
Re: Installing a Lock-Right in a V6 4 Pinion Rear [Re: ZUK] #690943 02/01/06 08:02 PM
ZUK Offline
ya...all I could find was this EZ install pic into a 4 pinion case....only 4 parts plus springs
mostly stock
Re: Installing a Lock-Right in a V6 4 Pinion Rear [Re: ZUK] #690944 02/01/06 09:31 PM
87Toy4x4 Offline OP
yeah thats what it looks like. i guess i have to get them to send me some springs. thanks.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6411 MB (Peak: 0.7620 MB) Data Comp: Off Server Time: 2026-11-02 23:32:21 UTC
