Bypass Cat Converter 4x4 V6 ?? #691359 01/30/06 05:34 AM
TheToeCutter Offline OP
1994 V6 4x4 California truck, 138k miles, stock everything.
I wanted to get your guys opinion on an idea I had. I was thinking about having a straight exhaust pipe made which I could just bolt in place of my catalytic converter (in between smog checks of course). It appears if I buy two flanges I could just have a straight pipe welded to each of them, unbolt the old cat converter, bolt in the new straigt through pipe and I would be all set.
Anyone think the power increase would be worth it ? Any potentional check engine light problems etc ?
O2 sensor is right before Cat in picture below (hopefully the link will work)
or
http://www.kodakgallery.com/PhotoVi...sperpage=12&navfolderid=2006
Re: Bypass Cat Converter 4x4 V6 ?? [Re: TheToeCutter] #691360 01/30/06 06:57 AM
If someone could tell me how to add an image from my hard drive to this post I would appreciate it.
Or if you can only post if the picture is on a website, let me know. ( I don't think the way I have it setup now is working) Thanks !
Re: Bypass Cat Converter 4x4 V6 ?? [Re: TheToeCutter] #691361 01/30/06 07:03 AM
OOP'S Offline
[color:"blue"] You will not notice that much except helping to make the air dirtier that we all breathe. In addition, if you are caught it is a big fine for tampering with the SMOG devices in a vehicle that is registered for street use in California!!!! [/color]
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Bypass Cat Converter 4x4 V6 ?? [Re: TheToeCutter] #691362 01/30/06 02:59 PM
1
1FastSS Offline
Not sure it would be worth it. I don't even have a lift and if someone (maybe a cop) is sitting next to me, he will easily be able to see my exhaust. Too easy to see since it's right under the drivers seat. I wouldn't mess with it. The fine for no cat(s) is quite steep from what I've heard....
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: Bypass Cat Converter 4x4 V6 ?? [Re: OOP'S] #691363 01/30/06 03:59 PM
Thanks for the replies..yeah I figured it wouldn't be worth it.
OOPS you have a PM I sent you about a power steering reservoir. Let me know your thoughts..thanks.
Re: Bypass Cat Converter 4x4 V6 ?? [Re: TheToeCutter] #691364 01/31/06 10:43 AM
Snowtoy Offline
W/o the cat you would have no increase in power in the area powerband most of us use w/the 3.0, you might get some power above 4500(not really a usable rpm range).
If you are looking for a better flowing exhaust, pick up a new cat at Autozone for $55(universal) or $75(bolt-on).
Re: Bypass Cat Converter 4x4 V6 ?? [Re: Snowtoy] #691365 01/31/06 07:31 PM
Rauch_Off_Road Offline
If the cat is getting clogged you will deffinately notice a difference, otherwise a highflow cat will give you the same benefit as a straight through setup about 5hp and With a highflow you won't have to ever touch it. Don't cali trucks have 2 O2 sensors anyways?
I saw someone had posted a cheep highflow cat here before, I think it was like $75 or something like that.
(aka suprathepeg, aka Sean)
Re: Bypass Cat Converter 4x4 V6 ?? [Re: Rauch_Off_Road] #691366 02/02/06 01:15 AM
Snowtoy Offline
Not sure what year they started on the 3.0, my '90 only has 1, same with my '91 4cyl. I know that in '92 4 cyl.s started coming with 2, I am not sure how long this was done for.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6228 MB (Peak: 0.7224 MB) Data Comp: Off Server Time: 2026-06-23 01:18:40 UTC
