Driveshaft center bearing (Carrier Bearing?) #691638 01/31/06 04:53 AM
1
1FastSS Offline OP
How much play should there be? I can grab the driveshaft and move it up and down about 1/2 to 3/4 of an inch. Is that too much? It doesn't seem to be making any noise, just the bushing seems to be shot. It looks elongated. Can I rotate the bushing? Can I buy just the bushing?
Thanks.
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: Driveshaft center bearing (Carrier Bearing?) [Re: 1FastSS] #691639 01/31/06 05:49 AM
OOP'S Offline
There is not a bushing in there it is a bearing!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Driveshaft center bearing (Carrier Bearing?) [Re: OOP'S] #691640 01/31/06 03:05 PM
1
1FastSS Offline OP
I know, but there is a big rubber thing (bushing is what I would call it) around the bearing. It seems loose to me. How much should I be able to move the driveshaft?
Re: Driveshaft center bearing (Carrier Bearing?) [Re: 1FastSS] #691641 01/31/06 03:27 PM
OOP'S Offline
I looked in the FSM and it did not give a spec. When they are new, there is hardly any movement at all. Here is how I fixed mine. It is a 1.5 pillow block bearing. If it is a DD, I do not know if I would recommend this.
David Fritzsche
Roseville, CA
Re: Driveshaft center bearing (Carrier Bearing?) [Re: OOP'S] #691642 01/31/06 03:47 PM
1
1FastSS Offline OP
That looks pretty solid. Does it give you vibration issues? I guess I need to look at a new one. Mines almost 14 years old and 145k miles. I found a new one for $105 online....... Here
Think it's just as good as an OEM one?
Thanks for your help.....
Re: Driveshaft center bearing (Carrier Bearing?) [Re: 1FastSS] #691643 01/31/06 07:29 PM
OOP'S Offline
The last one that I replaced was an aftermarket one and it only lasted about six months. Then I went to a one-piece D-shaft for a few years. I am not saying that the aftermarket one was any better or any worse you have to remember that I do extreme wheeling. When I first put the pillow block bearing I did have, a vibration so since then I have rubber mounted it and it has helped but my truck sees very little road time.
Hendrix Motorsports has come out with an eliminator for it also:
[color:"blue"] Most drive-train combinations will require a two-piece front drive shaft. For this reason, Hendrix Motorsports developed a billet aluminum carrier bearing for use with Toyota two-piece drive shafts. $58.95 includes mounting hardware and snap ring (bearing not included[/color]
You would need to call them and talk to them about it. Here is there web page and phone number:
805-550-3196
http://hendrixmotorsports.com/index.html
David Fritzsche
Roseville, CA
Re: Driveshaft center bearing (Carrier Bearing?) [Re: 1FastSS] #691644 01/31/06 10:58 PM
here is another option. go one-piece.. one piece driveshaft
Re: Driveshaft center bearing (Carrier Bearing?) [Re: 1FastSS] #691645 02/01/06 03:48 AM
trythis Offline
Mine is the same way, I can lift it 1/2" but I get no vibration, and it looks like it is in a bushing, I wonder if there are any with polyurethane bushings.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.011s) Memory: 0.6217 MB (Peak: 0.7178 MB) Data Comp: Off Server Time: 2026-07-14 19:18:59 UTC
