Re: Fan Bracket [Re: Toy4x] #691775 02/01/06 03:11 PM
I
irish_ROCKS Offline OP
thanks alot guys!!!!!!!!! u can see the lil wheels turning inside my head lol now im following yall (kinda).........i think ill go with tryin2 replace the fan bracket.... i suck with electric ... the mechanic said i needa replace the water pump.... he jus glanced at it ......ima tow it 2 the ranch sat an work on it myself thanks guys how hard is that bracket 2 change??
irish kicks ASS!!!!! ;-p
Re: engine fan shaft???? [Re: irish_ROCKS] #691776 02/02/06 05:52 AM
O
oldsub86 Offline
Anyone have the part number for the fan idler bracket described in this thread? I was trying to check prices online but cannot come up with the correct piece without the number.
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: Fan Bracket [Re: irish_ROCKS] #691777 02/02/06 02:24 PM
Toy4x Offline
to change, IIRC,
drain coolant, remove upper water neck & studs (female torx works great here, or back2back nuts), remove upper Timing Belt cover.
If your model does not have the hydraulic T-Belt tensioner, simply remove the brkt.
If you have the tensioner, remove the hydralic piston actuator (pass side), then bracket.
Reassembly requires putting a retaining pin in the actuator, a drill bit will do.
Thing is, if you in there lookin at the Tbelt, you oughta ck it out along with all the idlers and wtr pump.
GL
Re: Fan Bracket [Re: Toy4x] #691778 02/02/06 07:43 PM
I
yeah does anybody have the part number?? an wat is it called exactly??? fan bracket ? fan idler bracket?? i was looking 4 one on here but the guy didnt follow an wanted 2 know specifically wat its called...........an im goin2 check junkyards tomorrow............ohhh yeah i own a 90 4runner parts truck in maryland..........but it has a 4 cylinder my buddy looked at it an said its a totally dif set up??? thanks guys
Re: Fan Bracket [Re: irish_ROCKS] #691779 02/15/06 04:30 AM
I
my fan bracket FINALLY came YAAAAAAY!!!!!!!!!!!!! soo tomorrow morning i got my work cut out.......looks pretty easy ......ill prolly have fun gettin all the belts lined back up.and theres a bracket 2 the left of it that i needa take off that might give me problems........other n that looks like even i wont have problems knock on wood......i cant wait 2 get my wheels back im sick of the 2wd jeep cherokee an 87 chev.......i want MY truck lol ill keep yall posted
Re: Fan Bracket [Re: irish_ROCKS] #691780 02/21/06 10:05 PM
I
ON THE ROAD AGAIN FINALLLLLLLLYYY!!!!!!!!!!! as of thurs noon THANKS sooooo much all yall that gave me advice or ideas i owe yall........got the radiator off ebay (mounting holes didnt line up with the ones on the truck OF COURSE) got the bracket offa that link 2 ebay THANKS tho one mountin hole was off n i ended up redrilling it i learned alot n now could do the hole mess in half the time lol thanks again yall <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Fan Bracket [Re: irish_ROCKS] #691781 05/16/06 04:08 AM
chuckelbarry Offline
Yea this thread was vary helpfull i just did this mod on my 4runner. Love the results <img src="/forums/images/graemlins/kewl.gif" alt="" /> My wright up
Re: Fan Bracket [Re: chuckelbarry] #691782 05/16/09 06:42 PM
Am i crazy? I did this mod a wile ago. since then great results. I have had the fan stick on ones or twice (blew out the relay with some air fixed it) My question is does the alternator spin slower now with the removal of the center pulley? or is it just my alternator not coping well with the new load? at idle the dash gauge seems a bit low.
Re: Fan Bracket [Re: chuckelbarry] #691783 05/17/09 04:18 PM
OOP'S Offline
It does not spin slower; it is being run by the same pulley on the engine crank. Electric put more load on the electrical system and the alternator is only a 60 amp at the most if it is stock.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Fan Bracket [Re: OOP'S] #691784 05/17/09 06:38 PM
Yep it's a stock alt for now. guess its time to upgrade the alt. humm <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6371 MB (Peak: 0.7634 MB) Data Comp: Off Server Time: 2026-07-16 03:39:43 UTC
