SOHC transmission, same as Aisin Warner to fit '90 Montero? #692432 02/02/06 12:34 AM
sidecardog Offline OP
Hey guys,
I'm stuck in Nevada and am putting in a new auto tranny in my 1990 Montero.
I know that the original is an Aisin-Warner A44DL lockup with a Mitsubishi designation of KM148.
I found a tranny on ebay imported from Japan that claims to fit. It says it's a SOHC Mitsubishi tranny. I don't know what this means. Any idea if will actually fit?
I don't know how to link yet but the item number is 8033989916 if you want to check it out.
Thanks for your help everyone.
Matt
2002 Montego Limited, 3.5 V6, 90K, just purchased
1990 Montero LS, LWB, AUTO, 3.0 V6, 250K, 2" SL, 31" tires--SOLD
1959 Vespa VBA150 all original w/sidecar
Re: SOHC transmission, same as Aisin Warner to fit '90 Montero? [Re: sidecardog] #692433 02/02/06 01:19 AM
Also,
A tranny from certified transmission.com seems like the best choice in terms of reliability but it'll run be $1637. The one on ebay is $800 including shipping. It's guaranteeded for 90 days if its the wrong part. Should I take the gamble and save $800?
Matt <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: SOHC transmission, same as Aisin Warner to fit '90 Montero? [Re: sidecardog] #692434 02/02/06 01:41 AM
Charlie Belew Offline
I had my '93 tranny rebuilt twice. Does the $1600 include R&R? 1600-1800 is about right for a rebuilt with torque convertor. As has been said before, for safety sake use OEM fluid...
If you plan on keeping it do the rebuilt. Once rebuilt should last 200k more. Go the cheaper route if you can stick around town/motel in case the trans is the wrong part.
None
Re: SOHC transmission, same as Aisin Warner to fit '90 Montero? [Re: Charlie Belew] #692435 02/02/06 02:09 AM
$1600 is just the price of the rebuilt tranny from certified transmissions. Labor is extra. If you include shipping time, the ebay tranny will cost about $1000 less (and I keep my current tranny). I know that a rebuild is the best way to go but I really don't have the extra $1000. Thoughts? Thanks <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: SOHC transmission, same as Aisin Warner to fit '90 Montero? [Re: sidecardog] #692436 02/02/06 03:24 AM
DaphneD Offline
An A/T from the Single OverHead Cam engine could be either the lockup or the non-lockup model. Both will work, but the lockup is the best choice for the LWB.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6076 MB (Peak: 0.6731 MB) Data Comp: Off Server Time: 2026-06-22 07:35:06 UTC
