Timing cover bolt...broken #692457 02/02/06 02:53 AM
dewmtndew Offline OP
While installing my timing cover the bottom left bolt, with the 14mm head, snapped inside the block. I dont think there is much if any sticking out of the block. What would be my best bet for getting this out without taking the timing cover off? Or would I be fine just leaving it as is?
erick
85 Pickup
33s, lift, EB cam, header, exhaust...
Re: Timing cover bolt...broken [Re: dewmtndew] #692458 02/02/06 02:57 AM
kewlynx Offline
See if you can get on it with an angle drill and a reverse drill bit(NOT an extractor) -- and some PB Blaster or Aerokroil. Stay as perpendicular as you can; you might be able to spin it out.
I take it you don't have an AC unit in the way (yet); that's helpful.
Chase the threads before installing a new bolt to make sure it's still good to go.
Personally, I don't like leaving stuff like that hang unless it's to limp it home or to a shop.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5879 MB (Peak: 0.6358 MB) Data Comp: Off Server Time: 2026-07-09 21:14:06 UTC
