Crapola MPG
#692482
02/02/06 04:03 AM
I have a 93 22re reg cab 5 spd with 32's. Prob is lately Im getting horrible gas milage. (14mpg highway) I just changed oil and filters, checked tire pressure. Any ideas?
89 YJ, 258cid, ax-15, Webber carb, HEI, 33x12.5's, nerfs, custom diamond plate (for sale)
93 Yote P/U, 22RE, trim'd front, exaust, 32"BFG's (for sale)
Re: Crapola MPG
[Re: ChokeUoutcold]
#692483
02/02/06 04:45 AM
What gears do you have in the diffs? Is that corrected or un-corrected mileage? Does it have a lift on it. How wide are the tires
"Serenity through Sobriety"
Re: Crapola MPG
[Re: OOP'S]
#692484
02/02/06 04:59 AM
What gears do you have in the diffs? Is that corrected or un-corrected mileage? Does it have a lift on it. How wide are the tires Gotta check on gears, 14 mpg is what I'm getting now-was getting 20 on highway, minor lift-s/o in back some trimin' up front, 12.50 tires
Re: Crapola MPG
[Re: ChokeUoutcold]
#692485
02/02/06 02:01 PM
It could be a bad O2 sensor. They dont always trigger the CEL when they go bad. Either check for codes diagnostics or physically test the sensor as shown here... O2 sensor There is also a general drop of mpg's in the winter due to oxygenated gas but not to the extent of 14mpg. Fresh plugs/wires/cap/rotor and timing might also help. P.S. Hello from up the river and welcome to the forum. <img src="/forums/images/graemlins/cheers.gif" alt="" /> I actually live north of Hudson. Send me a pm if ya like.
'04 Taco x-cab 3RZ FE stock (daily driver) '90 x-cab 22RE stock '82 Hilux 6" lift (ACES HI) '82 2-Hiluxs' Rally Edition (parts) '81 Hilux 3" lift (parts/restore)
Re: Crapola MPG
[Re: ChokeUoutcold]
#692486
02/02/06 02:26 PM
What gears do you have in the diffs? Is that corrected or un-corrected mileage? Does it have a lift on it. How wide are the tires Gotta check on gears, 14 mpg is what I'm getting now-was getting 20 on highway, minor lift-s/o in back some trimin' up front, 12.50 tires What changed between the time you were getting 20 and 14? And what's an "s/o"?
Brian K. Gallus I have nothing important to say.
Re: Crapola MPG
[Re: ChokeUoutcold]
#692487
02/02/06 03:53 PM
Well considering your tire size jumped by almost 14% and I'm guessing you didn't fix the speedo, your mileage is more like 16.
I'm going to agree with the 02 sensor, since it was such a sudden drop. It may need a tune up too. You should still be able to get almost 20 out of that truck though. Regearing would help too.
90 pickup, 22RE, stiff-ass Ranchos, 2.25 catback, 4:1 header, conical intake, 15x7 ICW alloys, 32x11.50 Dunlop Mud Rovers, 4.56s w/v6 rear
-Farm truck until school is done...then plans
2000 Honda CRV EX 5 speed
-Driver
Re: Crapola MPG
[Re: jcssurf]
#692488
02/03/06 12:53 AM
S/O = Spring Over, I haven't changed anything on the truck except my sirius antenna, How do I tell what gears I have??
Re: Crapola MPG
[Re: ChokeUoutcold]
#692489
02/03/06 02:10 AM
Just to clarify, this is a 4wd? You mentioned the S/O, which is stick on the 4wd. If you did this on a 2wd, then your actual mileage would be much better.
1986 Pickup extracab longbed "Woody edition" SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD" 94 2wd v6 extracab 04 Outback Wagon- wife's/family car
Re: Crapola MPG
[Re: ChokeUoutcold]
#692490
02/03/06 04:02 AM
What about a stuck EGR valve. I just went through something very similar. Pulled the EGR and everything appeared to function. I couldn't find a gasket in stock so I made my own along with a couple of block off plates. I can't believe how much better it runs now. The EGR was definitely malfunctioning on mine. Just a thought...
'86 Toyo 4wd '04 600RR
