Charging System Problems? ? ? ? #692720 02/03/06 02:24 AM
bayrunner Offline OP
Hey Guys ____ WHERE is theö voltage regulatorö LOCATED on an 84 22r 4runner, I know on an 85 22re itÆs in the alternator. IÆm having symptoms of a faulty alternator. Charge light on, its running rough, and the tachometer is going crazy (up and down) wipers slowing down. I did tap on the alternator once and the symptom disappeared but came back, IÆm also thinking intermittent alternator (worn brushes) problems, had it checked out, it was good. So, just for good measure IÆm going to replace the voltage regulator for good measure and go from there. Any ideas are WELCOMED ________ THANKS in advance BAYRUNNER
Re: Charging System Problems? ? ? ? [Re: bayrunner] #692721 02/03/06 02:47 AM
kewlynx Offline
Left fender next to the little black box that holds the terminal lug for your B+ wire to transition across the front to the fusebox. Follow your harness; it's about the size of a pack of cards.
**ubi apis- ibi salus**
Re: Charging System Problems? ? ? ? [Re: bayrunner] #692722 02/03/06 03:54 AM
TimsToyo Offline
FYI, Old school trick is to hold a long handle screw driver next to the back of the alternator (Mind the positive cable). The harder the mangetic pull on the screwdriver the more it's charging. So if you get into another "episode" you can check the alternator to see if it's charging 100%.
Hook up a volt meter to the battery while the engines running and monitor the voltage. If it peaks above 14.0v the regulator may be bad. If it stay below 13.5v but still fluctuates, then it's probably the brushes.
'86 Toyo 4wd
'04 600RR
Re: Charging System Problems? ? ? ? [Re: TimsToyo] #692723 02/03/06 04:25 AM
L
lookmomnobrains Offline
on my 84 p/u its on the driver side fender next to the coil. i just changed mine recently. has a 5 or 6 wire plug.
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: Charging System Problems? ? ? ? [Re: bayrunner] #692724 02/03/06 09:16 AM
kewlynx Offline
PM'd you.
Re: Charging System Problems? ? ? ? [Re: kewlynx] #692725 02/05/06 05:03 AM
____ Thanks Margie_______ IÆve got a few more things to check on (check all grounds etc.)The weather is a determining factor for me working on truck(no garage)up here in the Pacific Northwest, its been raining and storming here lately. So I put things on hold, but, I DO have to getting going on it and resolve the problem soon.. Thanks for the interest. _____ THANKS BAYRUNNER
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6107 MB (Peak: 0.6803 MB) Data Comp: Off Server Time: 2026-06-07 08:40:57 UTC
