Will a bad O2 Sensor cause a rough Idle???? #692885 02/03/06 02:27 PM
I have a rough idle on my 1993 4x4 with the 22re in it. It has about 125000 miles. I have had the o2 sensor code come up before but had it looked at and my mechanic said it seemed to be working fine. Can a bad O2 sensor cause a rough idle once truck has been warmed up?
Also where is the cheapest place to get a "factory" sensor from?
Thanks for any help
Re: Will a bad O2 Sensor cause a rough Idle???? #692886 02/03/06 04:09 PM
1
1986xtracab Offline
An O2 sensor code doesn't always mean that the O2 sensor is bad.
Re: Will a bad O2 Sensor cause a rough Idle???? [Re: 1986xtracab] #692887 02/03/06 05:31 PM
Ya I wasn't sure of that....but I still have a rough idle.
Re: Will a bad O2 Sensor cause a rough Idle???? #692888 02/03/06 06:35 PM
willzrunna96 Offline
autozone can now order denso o2 sensors... stay away from bosch
Re: Will a bad O2 Sensor cause a rough Idle???? [Re: willzrunna96] #692889 02/03/06 07:08 PM
4Crawler Offline
See if the EGR valve is sticking open, tap on it while idling rough and see if it clears up.
TPS IDLe setting could also cause a rough idle: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
http://www.sparkplugs.com/ has good prices on the Denso sensors if you think yours is bad.
Re: Will a bad O2 Sensor cause a rough Idle???? [Re: 4Crawler] #692890 02/03/06 08:39 PM
5
5VZ Offline
I believe the O2 sensor is not in use during idle - so, no, it's something else.
94 4Runner, 5VZ-FE, A340H
Re: Will a bad O2 Sensor cause a rough Idle???? [Re: 5VZ] #692891 02/03/06 11:05 PM
TimsToyo Offline
Why would it not be in use during idle? I would think the ECU needs to know what the A/F ratio is no matter what the rpm. <img src="/forums/images/graemlins/confused.gif" alt="" />
'86 Toyo 4wd
'04 600RR
Re: Will a bad O2 Sensor cause a rough Idle???? [Re: TimsToyo] #692892 02/03/06 11:06 PM
4Crawler Offline
My A/F gauge flicks back and forth at idle most of the time, although slower than normal. So I think the sensor is being read and the fuel mixture adjusted over time.
Re: Will a bad O2 Sensor cause a rough Idle???? [Re: 4Crawler] #692893 02/04/06 02:43 AM
OK I will try tapping the egr and see what it does. I might just go ahead and take it out and clean it with some carb cleaner since it has never been done.
Thanks guys you have been a big help
Re: Will a bad O2 Sensor cause a rough Idle???? #692894 02/04/06 05:13 AM
trythis Offline
Got a vaccum tester? the FSM has a great set of egr and related parts that will diagnose the rough idle. You thermostat can end up causing that if the temperature sensor doesnt get hot it wont open the egr valve. Its easy to test though and eliminates the guessing.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6368 MB (Peak: 0.7545 MB) Data Comp: Off Server Time: 2026-06-07 06:00:42 UTC
