Re: Part # search for bearing... #692934 02/03/06 06:52 PM
4
4xGeek Offline OP
Having trouble finding a part # for the bearings on the front passenger side driveshaft at the diff... Anyone have this handy? Doesn't have to be stock - Timken is fine.
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Part # search for bearing... [Re: 4xGeek] #692935 02/03/06 07:22 PM
surlynkid Offline
are you talking about the needle bearings inside the housing? if so, i have the OEM part number at the house. i messed up one of those getting the carrier bearing out.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Part # search for bearing... [Re: surlynkid] #692936 02/03/06 10:10 PM
4
4xGeek Offline OP
How many separate bearings/race/seal sets are there in the front diff? 3? Suppose I'll need any & all part #'s you've got...
Been experiencing an intermittent wobble in the front end. Did the inner & outer front wheel bearings a few weeks ago... Noticed this past weekend when rolling around under the rig that the pass. side driveshaft has a considerable amount of play at the diff (+1/4" up & down). Figured since I'm about to finally do my R&P, might as well have the bearings done at the same time - but since I just did the wheel bearings I don't need to buy a 'master kit'; Just need the ones in the diff. Can't seem to find the #'s or someone knowledgeable on the phone... Arrrgh. <img src="/forums/images/graemlins/shiner.gif" alt="" />
4xGeek (Chris)
Re: Part # search for bearing... [Re: 4xGeek] #692937 02/03/06 10:36 PM
surlynkid Offline
Just tell the person on the phone that you have a 1993 V6 4runner with ADD. That will get you what you need. You have carrier bearings, pinion bearings, and then the internal needle bearings. that is all.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Part # search for bearing... [Re: surlynkid] #692938 02/04/06 01:20 AM
4
4xGeek Offline OP
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sweet... That worked. Thanks man! <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6072 MB (Peak: 0.6717 MB) Data Comp: Off Server Time: 2026-06-10 01:48:00 UTC
