Oil Pan bolt torque... #693413 02/05/06 04:09 AM
84toyota Offline OP
Can somebody tell me what the torque is supposed to be on oil pan bolts? My '84 factory service manual says [color:"red"] 52 ft/lbs. [/color] <img src="/forums/images/graemlins/scared.gif" alt="" />
I sheared one off attempting to torque it... I dropped the torque wrench to 25 ft/lbs. <img src="/forums/images/graemlins/confused.gif" alt="" /> and sheared another... I finally just cinched them down to about 12 ft/lbs. Upon looking at the back of the fsm for 8mm bolts with the number 4 on the head, it says to torque those to 9 ft/lbs.
Why would the factory service manual state 52 ft/lbs in one section, then 9 ft/lbs at the back? What should I torque them to? By the way - this is for an '84 22r.
Ken
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: Oil Pan bolt torque... [Re: 84toyota] #693414 02/05/06 04:13 AM
84toyota Offline OP
Sorry guys and gals... I should have looked at the post about the loose oil pan bolts... found my torque values right there! Sorry for my brain fart! But why would the fsm state 52 ft/lbs?
Re: Oil Pan bolt torque... [Re: 84toyota] #693415 02/05/06 04:21 AM
dewmtndew Offline
does it say in/lbs??? those little bolts deffinatly dont need 52 lbs!
erick
85 Pickup
33s, lift, EB cam, header, exhaust...
Re: Oil Pan bolt torque... [Re: dewmtndew] #693416 02/05/06 05:25 AM
kyle-22r Offline
i'd say more along the lines of 52 in/lbs! the oil pan just needs to be on tight enough to not leak.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Oil Pan bolt torque... [Re: kyle-22r] #693417 02/05/06 06:18 AM
87Toy4x4 Offline
im pretty sure the specs are somewhere along the lines of 10-12 ft/lbs.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6057 MB (Peak: 0.6700 MB) Data Comp: Off Server Time: 2026-06-07 07:06:18 UTC
