Re: Think I blew my rear diff... #693826 02/07/06 07:48 PM
87Toy4x4 Offline
are you sure that diff wasnt 4.56's instead of 4.88's? if theres binding in 4wd its highly probably that you have diff. gear ratios front and rear.
Re: Think I blew my rear diff... #693827 02/07/06 11:36 PM
Red_Chili Offline
Toyota Section Staffer
... I am starting to feel hesitant about using parts from the salvage yard. I paid 350 for the used diff, and it seems like I could have the diff rebuilt with better parts for that much. ...
OhMy.
That's obscene.
As far as used parts, I've built a whole truck out of them. That would not be the issue here.
-Bill
Re: Think I blew my rear diff... #693828 02/08/06 01:15 AM
Seldom_Seen Offline
I have a good rebuildable Toy 4.88 diff. Ring and Pinion check out fine. Bearings were ?able. Tore it down and was going to put an ARB and new bearings in, but plans have changed.
Throw some new bearings at it, git'er done, get'er done right and don't look back.
I'm in Denver and could meet you some where.
PM me if interested.
Re: Think I blew my rear diff... [Re: Seldom_Seen] #693829 02/09/06 01:06 AM
TNToy Offline
Pull that bad boy apart and LOOK. We can virtually gaurantee that only the third member will need replaced. $350 for a chunk is crazy. I've bought a front axle ($250)& rear end($150), a v6 diff ($90), and 2 4cylinder chunks ($50 and $120 - too much for the second one but I needed it NOW).
Stay away from junkyards unless a friend works there. Look for parts on ebay and the FOR SALE sections of offroad forums. Offroaders are cheap penny-pinchers. So look for deals there.
As ZUK pointed out: If you haven't spun a bearing on the carrier or pinion, you won't need a new third member. Yours will just need rebuilt. It really sounds to me like the pinion bearings were run dry because the leaking rearend starved them of lubrication when the lube level got too low. Heck, if you got really lucky and just fried pinion bearings, you MIGHT not even need new gears, again assuming the bearings haven't spun.
I also say it's likely that those gears were 4.56s... and the fronts were 4.88. Or vice versa. People just assume their stock ratio is X.XX because it's got this motor and that tire package. But you've gotta COUNT THE TEETH to check.
I've bought 2 diffs with 4.56s in them, both of whom were from people who told me they were 4.10 gears. Always count the teeth on the two gears and divide 'em to get the true ratio. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.012s) Memory: 0.6050 MB (Peak: 0.6763 MB) Data Comp: Off Server Time: 2026-11-02 21:52:33 UTC
