Diamond Plate Fabrication Help #694036 02/07/06 02:26 PM
ChokeUoutcold Offline OP
OOps, clicked on the wrong forum please move thanks
Just picked up a new cutting wheel (already destroyed my toyota tailgate with it <img src="/forums/images/graemlins/lol.gif" alt="" />) and I'm going to grab a sheet of aluminum diamond-plate. I want to fabricate some rockers, corners, a frame cover, and fender tops. The plan is to create a template, cut and trim. The question(s) are:
What is the best way to attach this to the body..bolts, rivets??? And secondly, is thier a way to bend the plate at home to make the corners. I don't have any specailized tools for this. Any advice appreciated.
89 YJ, 258cid, ax-15, Webber carb, HEI, 33x12.5's, nerfs, custom diamond plate
(for sale)
93 Yote P/U, 22RE, trim'd front, exaust, 32"BFG's
(for sale)
Re: Diamond Plate Fabrication Help [Re: ChokeUoutcold] #694037 02/07/06 07:55 PM
Talon84X4 Offline
as for special tools, sometimes there just isn't the right one, from my welding classes, one of them was an art class and i had to find ways to bend all different thicknesses of sheet and solid stock to look and fit just how i wanted....i'd like to think i pulled it off quite well....will have to upload a pic of the work i did, got to put it in the college art show...anyways
for bending corners, you could use some pipe, preferably something bolted to the ground or something very very sturdy, being able to clamp it would be great, for those straight bends i used a vice with thick steel plates to extend it's "clamping" length, and then a steel pipe of the diameter of the bend i wanted to make laying on top, slow and steady preasure got me the bends i wanted even without heat
hope that helps a little, sorry if i started to drone
'84 PU low & slow
Central Valley Crawlers
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5878 MB (Peak: 0.6360 MB) Data Comp: Off Server Time: 2026-06-22 10:11:16 UTC
