upper balljoints #694179 02/08/06 01:09 AM
smansfield Offline OP
i have to replace my uppers for the first time on my 93 xtra
cab(320,000klm's),and i was wondering if i need to put something between the a arms,because of the tension from the ifs arm?i was thinking of using a bottle jack.anyone with any advice
1993 toy pickup xcab 4x4
Re: upper balljoints [Re: smansfield] #694180 02/08/06 01:45 AM
A
allochris Offline
correct, bottle jack makes it easy
to keep the upper a arm up to take out your upper ball joint.
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: upper balljoints [Re: smansfield] #694181 02/08/06 02:43 AM
O
oldsub86 Offline
I did this last fall and I think that I just jacked the truck up and put it on the stands and then pulled the uppers. The upper A arm drops to the stop and can't go any lower. I think I had to pry down on the lower A arm in order to get the ball joint out.
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: upper balljoints [Re: oldsub86] #694182 02/08/06 04:19 AM
i have had two different toys 90,93,and put a combined 420k
on them over 12yrs and these are the first uppers,amazing!
Re: upper balljoints [Re: oldsub86] #694183 02/08/06 04:29 AM
Rusty Davis Offline
X2 Placing a block or something between the upper A arm and its droop stop will give you more room to work with, but it's really not necessary. If you were installing ball joint spacers on the other hand, it's almost imperative to have enough room to grind/hammer/bend the metal to fit.
This is pretty much edumacational and you should already know this, but don't put the jackstand on the lower control arm <img src="/forums/images/graemlins/shiner.gif" alt="" />
Oh and don't forget to seperate the BJ from the knuckle before you unbolt it....don't ask <img src="/forums/images/graemlins/ignore.gif" alt="" />
HTH
~R
94 4Runner 3.slow-5spd, 4" coils, 1.5" BJ spacers, 2" BL, 35x12.50 Nitto's, 5.29's with a front Lockrite and a rear Detroit; 250k miles and lots of offroad time...and by offroad I mean on jackstands.
Re: upper balljoints [Re: Rusty Davis] #694184 02/08/06 04:43 AM
i will be going at this tomorrow.thanks
Re: upper balljoints [Re: smansfield] #694185 02/08/06 05:22 AM
O
oldsub86 Offline
I think I also found it helpful to unbolt the front sway bar in order to get the lower a arm to drop far enough to pry out the upper ball joint. I ended up replacing the sway bar links too as they were about done.
Randy
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6124 MB (Peak: 0.6901 MB) Data Comp: Off Server Time: 2026-06-17 10:41:06 UTC
