Platinum or regular plugs in 2002 #694489 02/08/06 09:09 PM
jolly4x4 Offline OP
Took my 2002 into the dealer for the ball joint recall. It has 65K on it and they say its time for the timing belt and I gave them an OK on that (fan belts also need doing and they said while the fan belts are off I might as well do the timing belt). They will also replace front crank seal. So far sounds OK. Also having them do the plugs - thing here is that they say my motor calls for "regular plugs - changed every 30k." I am surprised that it didn't come with platinum. They made it sound like swapping with platinum would cause problems. Thoughts?
Jack Jolly
2002 4Runner Sport Edition
Gangsta Black
Re: Platinum or regular plugs in 2002 [Re: jolly4x4] #694490 02/08/06 10:20 PM
monsterhead Offline
I am not sure about the 2002 but the 2000 (V6) doesn't need a timing belt until it gets 90,000 on it. Sounds like the dealer wants to make some money off of you. Check it out to be sure that it is 65,000 for the timing belt on your 2002. I am not sure about the plugs but someone here will tell you. Good luck.
Re: Platinum or regular plugs in 2002 [Re: monsterhead] #694491 02/09/06 02:38 AM
F
Flannelman Offline
On the plugs the general consensous on plugs is stick with the OEM Denso or NGK Plug. Supposedly the ignition system isn't setup to run platinums but it doesn't really matter the plugs aren't hard to change and for 2.00 a plug it takes awhile to add up to what the dealer wants for platinums. I'd just change them with the OEM plugs. As for the timing belt I'd wait till 90k.
1997 T-100 100k and counting Green
5spd 4x4 Ext Cab isr mod Aisin Manual hubs
Re: Platinum or regular plugs in 2002 [Re: jolly4x4] #694492 02/09/06 03:09 AM
kewlynx Offline
Platinums are of a higher temperature scale. I've tried 'em once; didn't like 'em, and you could see the heat effect on the electrodes. Been with NGK's from there on out.
**ubi apis- ibi salus**
Re: Platinum or regular plugs in 2002 [Re: kewlynx] #694493 02/09/06 09:40 PM
jolly4x4 Offline OP
Well - after a $900 investment I have it back. They did the fan belts, plugs, timing belt, water pump (which they said was leaking), crank seal, cleaned the TB and set the idle - in addition to the ball joint recall. I realize that its a little early for the timing belt but while they had it apart (you know the rest). Something like brakes I would tackle myself but not stuff like this. Anyhow it fires right up, idles smoother, and seat-of-the-pants feel is better. I don't mind the cost too much as I plan to keep this thing for eternity. Hopefully some suspension work in the Spring (NOT at the stealer!).
Jack Jolly
Gangsta Black
Re: Platinum or regular plugs in 2002 [Re: jolly4x4] #694494 02/10/06 06:45 AM
kewlynx Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> At least they didn't half-fast the T'belt. Read the 3.4 timing belt article in our Toyota maintenance section (link above in header). You'll appreciate the work a bit more. <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6141 MB (Peak: 0.6845 MB) Data Comp: Off Server Time: 2026-06-07 04:26:31 UTC
