Detonation w/ bigger tires? #695013 02/10/06 12:12 AM
BIGBURLYNAKEDMAN Offline OP
I was thinking of replacing my stock 31X10.5 R15 BFG A/T's with something a little bigger (perhaps the 32X11.5 if they will fit). My truck is supercharged, and I was wondering if any of you have done this with a supercharger and experienced pinging from the increased tire weight when under load. Also, I know there is a perceived power loss from bigger tires, but will one size up really make any difference? Under any other circumstances, I'd just deal with the power loss, but in this case, I don't want to cause premature tranny failure or cause the engine to detonate just for the sake of "looking cool."
Thanks for any info at all! <img src="/forums/images/graemlins/patriot.gif" alt="" />
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: Detonation w/ bigger tires? [Re: BIGBURLYNAKEDMAN] #695014 02/10/06 05:22 PM
TCAO Offline
My truck is '02 DC w/SC,TRD Header&Exhaust V6 Auto Trans. and 32" or 265/75R-16 MTR tires. I have experiencing power loss right after switching tires, but then gain some power after I installed SC, however, the gas mileage is terrible with SC and bigger tires, and I don't step on the gas pedal very hard, and that will avoid the tranny problem... hopefully. Also, I have been using Mobil 1 syn. oil and Mobil 1 syn auto trans oil since the truck has only 3k on it.
Re: Detonation w/ bigger tires? [Re: TCAO] #695015 02/10/06 08:37 PM
99TRD Offline
I have a 99 with 32's on it and I've been running the truck with 32's since 40k miles and it has 85k now and I've never had a problem. There is a little bit of power loss but to be honest it isnt that much and I barely even notice. Gas mileage went down a little bit and now I get anywhere from 16-18 where with 31's I would get 17-19. Hope that helps ya <img src="/forums/images/graemlins/kewl.gif" alt="" />
1999 Black TRD Prerunner X-Cab V6
3 Revtek Lift
32x11.50 BFG AT
8"x2.5" Sway Away remote resi. coilovers and Total Chaos upper arms sitting in the garage begging to be installed
Re: Detonation w/ bigger tires? [Re: 99TRD] #695016 02/11/06 03:15 AM
Ya thanks for the input guys
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6030 MB (Peak: 0.6590 MB) Data Comp: Off Server Time: 2026-06-22 11:21:29 UTC
