front third member questions #695264 02/10/06 11:21 PM
Sturdy Offline OP
I have a front third member from a 90 Trooper with an ARB installed. Will this fit the 2nd Gen troopers? Specifically the 1993.
Mike
04 Tundra
01 Discovery
93 Trooper RS- Lifted, Locked- SOLD
93 Trooper RS- Teras, Lifted, Locked- ROLLED&SOLD
87 Trooper-Lift-SOLD
90 Trooper-Teras and lifts-SOLD
96 Trooper-Graveyard
Re: front third member questions [Re: Sturdy] #695265 02/11/06 12:32 AM
bob large Offline
Not 100% but I think it should.
The only differences in the 12 bolt that would create a problem are the differences in the ring gear size and axel spline count between the earlier 12 bolts and the 98/99 and newer troopers.
All the others should be interchangeable.
If you do try to swap them out let us know how it went.
Steve C
Re: front third member questions [Re: bob large] #695266 02/11/06 12:46 AM
strawmyers Offline
Isuzu Moderator
But he is talking about the front diff... so 12bolt variations really aren't an issue <img src="/forums/images/graemlins/wink.gif" alt="" />
To answer the original question; yes, the front 3rd member from a '90 Trooper will drop right into place in the front of a '93 Trooper. The only thing to check is that the gearing is the same between the two.
Sean Strawmyer
Re: front third member questions [Re: strawmyers] #695267 02/11/06 01:53 AM
bob large Offline
once again it helps to read. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
sorry <img src="/forums/images/graemlins/drunk.gif" alt="" />
Steve C
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6004 MB (Peak: 0.6572 MB) Data Comp: Off Server Time: 2026-07-13 14:31:50 UTC
