the wifes trooper... aka. grocery getter with an attitude. #695303 02/11/06 12:58 AM
grass13 Offline OP
was able to do a budget lift on my monty and working on getting another 2"'s out of it as well without spending much. but... while getting the tires rotated on the trooper the guy had it about 3"'s in the air, dam it looked sweet. what is the cheapest/easiest way to get mabey up to 2"'s of lift out of it, purchasing a lift kit aside? is there any adjustments that i can make to add a little lift? on my monty i just had to throw in some genII springs in the rear and crank my t-bars which gave me 2"'s of basically what contitutes a free lift kit... is there something similar i can do with the wifes trooper? ive got the biggest nastiest suedo street friendly (no, theyre not a/t radials, more of a mud/snow hybrid) tires i could put on the 16 in rims... it looks tons better then the other 99% of completly stock ones rolling around the slc valley. this should probably be in tech, but i didnt know if it was even possible given the rig and my lack of wrenching on it... as for the monty i know it inside outside upsidedown (literally) but i know very little about the wifes ride. btw, whats the achilles heal in the suspension & drivetrain if a lift is done? trailing arms? tirerod ends? rear d-shaft u-joint? tia isuzu guys <img src="/forums/images/graemlins/cheers.gif" alt="" />.
Re: the wifes trooper... aka. grocery getter with an attitude. [Re: grass13] #695304 02/11/06 01:22 AM
onebadtrooper Offline
Cool. All you'd need is some OME springs for the rear. I lifted my moms Vehicross, which is pretty much a SWB trooper. I got 2-1/2" with just the springs. Then you can crank up the front to match. after that all you'd need to do is get an alignment. I used the OME 912's which you can get for around $90~100. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: the wifes trooper... aka. grocery getter with an attitude. [Re: onebadtrooper] #695305 02/11/06 01:26 AM
Also the tie-rods are pretty much the weakest link. But Matt from indepenent4x has some really nice ones to take care of that.
Re: the wifes trooper... aka. grocery getter with an attitude. [Re: onebadtrooper] #695306 02/11/06 03:08 AM
Rezkid Offline
Some how I don't think this thing will be wheeled...ever. So the tie-rods are kind of a mut point.
'80 Isuzu LUV, 3" BL, cranked t-bars, small tires and not alotta power
'92 Rodeo...work in progress
Hmmmm...DIRT!!!
Re: the wifes trooper... aka. grocery getter with an attitude. [Re: onebadtrooper] #695307 02/11/06 04:04 AM
Y
ybnormal70 Offline
Where can you get the OME 912's for $90-$100??? I have been looking for them and they seem to be around the $165 range.
Thanks,
Kevin
'94 Trooper S 3.2SOHC, 5spd, Aisin hubs, OME919 w/ 2" coil spacers, Edelbrock shocks, fliped BJ's and spacers, 15" snowflakes w/33x12.50x15
Re: the wifes trooper... aka. grocery getter with an attitude. [Re: ybnormal70] #695308 02/11/06 04:06 AM
<img src="/forums/images/graemlins/scared.gif" alt="" /> oops I may of been wrong....I got mine for free, so I didn't really know <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: the wifes trooper... aka. grocery getter with an attitude. [Re: onebadtrooper] #695309 02/11/06 04:08 AM
Y
ybnormal70 Offline
Darn, I got my hopes up for nothing <img src="/forums/images/graemlins/frown.gif" alt="" />. Oh well, thanks for clarifying.
Thanks,
Kevin
Re: the wifes trooper... aka. grocery getter with an attitude. [Re: ybnormal70] #695310 02/11/06 06:07 AM
My OME 912's gave me about 1.5-2" of lift, I got them for 188 shipped from Matt at Indy4x. They ride a heckuva lot better too.
Getting a couple inches of lift is as simple as swapping out the rear coils and cranking the bars. Just remember: 4 turns = roughly 1 inch. I did 6 turns into each side.
Re: the wifes trooper... aka. grocery getter with an attitude. [Re: onebadtrooper] #695311 02/12/06 04:14 AM
grass13 Offline OP
thanks for the input... sounds just like doing my monty. thats easy enough, 2"'s should be plenty without having to go to a different set of rims and bigger tires. thanks alot guys... btw, anybody got a link for those coils? or is there a donor junkyard set that i shouldotta keep my eyes open for?
Re: the wifes trooper... aka. grocery getter with an attitude. [Re: grass13] #695312 02/12/06 04:22 AM
here's a link to the springs...
indy4x..
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6377 MB (Peak: 0.7615 MB) Data Comp: Off Server Time: 2026-11-01 21:11:22 UTC
