Shackle question #695353 02/11/06 02:47 AM
TrooperMonty Offline OP
I have stock 88 raider and looking for 1" to 1 1/2" lift from suspension. I've noticed lot of you have toyota shackle and wondering which toyota shackles you guys used and where can I get them (part number?)?
Any info you guys could share will be appreciated.
Jin
88 Montero 2.6L 2" Body Lift 32" Geolanders
Re: Shackle question [Re: TrooperMonty] #695354 02/11/06 06:56 AM
allsierra123 Offline
This may not be something you want to do.But this company out of england sells 2" lift shackle for the pajero and the L200.Which is the montero and mighty max for the US cars.Use the search feature on the site and it will bring up alot of aftermarket stuff they produce.
http://www.supertrux.com/acatalog/index.html
91 Mitsu Montero RS LWB PENDING
88 Cherokee Lifted and modded heavily. FOR SALE
91 vanagon syncro 1.9 TD SOLD
04 Suzuki Aerio Commuter SOLD
90 mits mighty max,v6 SOLD
94 Mits Diamante LS. Stock. TOTALED
71 VW Baja Bug SOLD
Re: Shackle question [Re: allsierra123] #695355 02/11/06 05:54 PM
powerRam50 Offline
there are 2" lift shackles for the front of 85 and older toyota's.they are almost the perfect size and they give a 2"lift for aur rigs.any 4x4 parts store can get these i got mine from summitracing.com.you do need to buy the right size and grade bolts.i used grade 8 zink plated bolts washers and nuts.
Re: Shackle question [Re: TrooperMonty] #695356 02/11/06 07:42 PM
Monty Offline
You can also use add a leaf in the spring packs
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
Re: Shackle question [Re: powerRam50] #695357 02/21/06 06:25 PM
rubberband Offline
What size bolts did you use?
Re: Shackle question [Re: rubberband] #695358 02/21/06 06:38 PM
powerRam50 Offline
if i remember right the top bolts were 6" long and the bottoms were 5 1/2".i dont remember the diameter becouse i just took in one of the new bushings so that they could find the largest dia meter bolt that would fit inside the bushing.
Re: Shackle question [Re: powerRam50] #695359 02/23/06 05:17 PM
BobShaw Offline
Bolt diameter is 5/8". Get 2 nuts each for locking as these are not sholder bolts.
The Summit Racing PN is something like 0084.
Suggest you get the OEM rubber busings replaced too.
Replace the bottom thick spring leaf with an JCW add-a-leaf pack.
This will not increase heigth but will give you more articulation.
Re: Shackle question [Re: BobShaw] #695360 02/24/06 08:15 PM
rubberband Offline
Thank you both for the information!
Re: Shackle question [Re: rubberband] #695361 02/25/06 09:34 AM
Oyaji_Jon Offline
I used the bolts that came with the shackles on my 89 and they worked just fine...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Shackle question [Re: Oyaji_Jon] #695362 02/25/06 08:08 PM
powerRam50 Offline
the bolt that came with mine were to large to fit in the stock bushings
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6359 MB (Peak: 0.7590 MB) Data Comp: Off Server Time: 2026-06-20 17:30:06 UTC
