Re: 22RE Knock Sensor [Re: Stomper] #695490 02/24/06 10:26 PM
4Crawler Offline
You can just see it, the yellow plug at about the 10:00 position from the oil filter:
Re: 22RE Knock Sensor [Re: Stomper] #695491 02/24/06 10:26 PM
Do a search under my user name scottdkg.....I had the same question and they pointed it out to me. I also have an 85 4runner and I replaced the knock sensor and runs great. No more check engine light coming on/off.
Re: 22RE Knock Sensor [Re: 4Crawler] #695492 02/24/06 11:17 PM
Stomper Offline
Thanks Roger I finaly got to looking around and I thought that was it but was still unsure. Not to find and replace mine and hope the light goes out.
http://www.4crawler.com/4x4/CheapTricks/Images/OilCooler.jpg
1985 4runner
Re: 22RE Knock Sensor #695493 02/24/06 11:18 PM
Stomper Offline
Thanks Scott Ill check it out.
1985 4runner
Re: 22RE Knock Sensor [Re: Stomper] #695494 03/02/06 03:43 AM
My check engine light has come on today. I just pulled the codes and I have a #5 O2 sensor and the #12 Knock sensor.
I have had codes "stack" before....fix one thing, and the other codes go away. Replace that O2 sensor, and betcha the knock sensor code goes with it. From what others are telling me the knock sensor RARELY fails. Besides, the dealer wants like $140 for one. <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: 22RE Knock Sensor #695495 03/02/06 03:46 AM
Well there is one possibility that comes to mind after reading your post and the info on code 12 and reviewing an 86 wiring schematic.
Make sure that you have a good ground to the engine block. Since the knock sensor's body completes the signal path to ground (engine block).
Also I assume the knock sensor wire is the same or similar to the later years, where there's an inner conductor and then an outer braided shield wire.
No, its just a plain wire. But your point about the ground is worth checking into. Heck, I can run a ring connector to the base of the sensor and ground it right good. Thanks....
Re: 22RE Knock Sensor #695496 03/02/06 06:54 AM
Well the wire schematic shows a shielded cable and my 92 has a shielded cable, but it's not easily visible on the sensor end of the cable it has shrink tube covering it and only the center conductor connects to the KNS, the shield only connects at the computer side. It's used only for RF/EMI shielding.
The KNS produces a frequency type signal and is vulnerable to noise and interference, the shielded cable helps to eliminate the interaction with stray RF and EMI from other surrounding circuits, It's very important that that shield has a good ground for the KNS signal to be interpreted properly.
If you look closer at the KNS circuit at the computer you will see it is shielded, just may be coved with shrink tube.
Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: 22RE Knock Sensor #695497 03/02/06 07:49 AM
Here, I found this link in my searches.
www.cybertrails.com
PHP: 7.4.33 Page Time: 0.019s Queries: 16 (0.015s) Memory: 0.6208 MB (Peak: 0.7360 MB) Data Comp: Off Server Time: 2026-11-18 03:41:00 UTC
