First gen rodeo/amigo.... #695512 02/11/06 07:26 PM
onebadtrooper Offline OP
I've been making a few rear bumper latly, and I'm just wondering if the rear frame area on first gen rodeo/amigo's are the same as first gen trooper? I've seen a few pictures, but I've never had a chance to measure. I know my troopers frame in the rear is 40" wide.
Thanks
_chris <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: First gen rodeo/amigo.... [Re: onebadtrooper] #695513 02/12/06 06:18 AM
does anybody have any pictures of the rear part of an amigo frame? Mainly the sides where the bumper mounts are. I've been searching everywhere for the past 3 1/2 hours <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Thanks.... <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: First gen rodeo/amigo.... [Re: onebadtrooper] #695514 02/12/06 07:01 AM
randii Offline
No, but I have a measuring tape...
Gimme a couple.
Randii
Re: First gen rodeo/amigo.... [Re: onebadtrooper] #695515 02/12/06 07:22 AM
randii Offline
I measured my 1990 Amigo crossmember for you.
The rear crossmember is 40" wide, from outside to outside. At the frame rails, the crossmember is 3" tall, and a few inches inboard of the frame rails, the lower edge drops down to allow a taller section height, about 3.75" tall. The upper edge of the frame rail is level all the way across.
There are three four-bolt rectangular clusters (left bumperette, trailer hitch, and right bumperette) and each is about 3.75" wide and about 1.75" tall. The outermost pair of bolts for the bumperette clusters is about 6.5" in from the outboard side of the frame on each side. The pairs of bolts for the hitch cluster is about 18.5" in from the outboard side of the frame on each side. Also, the bolt pattern is symmetrical, left-to-right.
HTH,
Randii
Re: First gen rodeo/amigo.... [Re: randii] #695516 02/12/06 06:31 PM
Hey thanks man, Its looks like its pretty much the same. You have two more holes on each side for your bumperettes.
Do you think this mount looks like it might work on the amigo? I found a picture of a rodeo, and it was different.
The front hole was lower than the rear one on the rodeo. My troopers two holes are level, as you can see in the pic.The holes in the mount are about 3" apart.
Thanks again... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: First gen rodeo/amigo.... [Re: onebadtrooper] #695517 02/12/06 09:43 PM
strawmyers Offline
Isuzu Moderator
Mine appear to be the same height. If there's a difference, its 1/8" or less.
Sean Strawmyer
Re: First gen rodeo/amigo.... [Re: strawmyers] #695518 02/12/06 10:56 PM
randii Offline
Sean nailed it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: First gen rodeo/amigo.... [Re: randii] #695519 02/13/06 12:11 AM
Ok cool, I seen this picture on RobG's site. And got kinda confused.
So amigo's arn't like this?...
Re: First gen rodeo/amigo.... [Re: onebadtrooper] #695520 02/15/06 04:02 PM
RodeoXS Offline
My 92 Rodeo is like Rob's. They are NOT in line with each other.
George <img src="/forums/images/graemlins/nana.gif" alt="" />
92 Rodeo XS 4x4
HomePage
Re: First gen rodeo/amigo.... [Re: RodeoXS] #695521 02/15/06 04:14 PM
Amigos are definetely in line or as Sean said no more than an 1/8th off. I tried to take a pic but dang digital eats batteries like a dang pacman. <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6370 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-07-13 14:36:43 UTC
