Fill hole on the tranny? #695552 02/11/06 10:25 PM
TimsToyo Offline OP
Which side is the fill hole for the 5-speed manual tranny on? Is it on the drivers side with a T-55 size torx bit? The '85 manual is confusing me.
'86 Toyo 4wd
'04 600RR
Re: Fill hole on the tranny? [Re: TimsToyo] #695553 02/12/06 12:49 AM
It's on the driver's side about mid transmission. It's not a torx though. It is a large hex plug, about 3/4" or 19mm.
Re: Fill hole on the tranny? #695554 02/12/06 01:22 AM
4WD22R Offline
DON'T REMOVE THE TORX BOLT!!!
mine says clearly on it "Do not remove"
IIRC, it's on the pass side.....
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Fill hole on the tranny? [Re: TimsToyo] #695555 02/12/06 01:25 AM
4Crawler Offline
Should be a hex head plug, close to the reverse light switch (i.e. the only thing with wires connected to the transmission) on the driver's side.
Re: Fill hole on the tranny? [Re: 4Crawler] #695556 02/12/06 02:23 AM
87Toy4x4 Offline
well when i got my truck the torx bit was on the drivers side and the fill on the passenger side. im pretty sure they were mixed up so i swapped them. its been good for 30k since then.
Re: Fill hole on the tranny? [Re: 87Toy4x4] #695557 02/12/06 04:46 PM
TimsToyo Offline OP
That's the way the '85 manual shows it but mine is on the drivers side. I had a neighbor come over last night and confirm it. I found out he's a damn good mechanic and worked strictly on the 22r motors for over a year. So needless to say I'm buying him a 12-pack when I get ready to replace the timing chain. <img src="/forums/images/graemlins/lol.gif" alt="" />
BTW, the oil was barely coming out of the fill hole and look clean. So I tighten the fill hole back up and will leave well enough alone. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks...
'86 Toyo 4wd
'04 600RR
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6083 MB (Peak: 0.6771 MB) Data Comp: Off Server Time: 2026-06-21 19:02:38 UTC
